Hi,
I'm running ffmpeg on macOS X, trying to encode a 544x304 avi file into DVD format. The first time I tried it, it worked, except that when I plugged er into the dvd player, the picture was way too big for the screen (like it was about 120% too big on both dimensions).
I looked at the converter and it said that it was taking the msmpeg4, yuv420p, 544x304 and making it into a mpeg2enc mpeg2, 720x480, 4000 kbps, 23.976 fps, no crop.
So I think, "no big deal, I'll just go into the Video tab and change the dimensions to 544x304." Well I do that and now it won't finish encoding. It gets to 100% but then can't create the Audio_TS/Video_TS files and fails.
Suggestions?
	544x304 is not supported by the dvd-video format(see www.videohelp.com/dvd#tech). But it should work fine to convert to 720x480 and keep the correct size so something else must have gone wrong. Have you checked the dvd on your computer? Same problem?
	544x304 has an aspect ratio of 1.79:1 (~16:9), so for optimal results, set the video size to "DVD 16:9"; no crop; no letterbox. Also check "Set 3:2" in the Options tab, to give the 23.976 fps video a "3:2 pulldown", for smooth playback on tv sets that expect a 29.97 fps signal.
	Hm yeah, that woulda been smart. I wish I had saved it  . Now I can't get the TS files back. . Now I can't get the TS files back.
 I tried again tonight with the 16:9 and 3:2 settings (great suggestions btw), but alas the encode failed. Apparently this time the video TS was created but the Audio TS was empty.
 EDIT: NEVER MIND.
 Apparently, while the Video TS was created and the Audio TS was empty, I loaded it up anyway with the Apple DVD player and it worked, with sound & subtitles!
 Kinda odd, but I threw it in the DVD player anyway and it worked like a charm.
 Thanks guys, you just saved christmas.
	The AUDIO_TS folder should be empty -- that's not a sign of an abnormal conversion. The VIDEO_TS folder has the .vob files that contain both audio and video of your movie. The AUDIO_TS folder is there for the special case of an audio DVD (basically, an audio CD, but with the larger capacity of a DVD disc).
  1GB AVI to DVD doesn't fit on DVDR?By juggaloninjachoo in forum Newbie / General discussionsReplies: 2Last Post: 18th Jan 2012, 14:32
  video doesn't fit my TV screenBy hzgg2 in forum Authoring (DVD)Replies: 3Last Post: 21st Jun 2008, 07:56
  AVI to DVD - Movie doesn't fit on screenBy tmac2085 in forum Newbie / General discussionsReplies: 2Last Post: 25th Jan 2008, 11:18
  DVD picture doesn't fill screen on new wide-screen TVBy ibzomie in forum Newbie / General discussionsReplies: 7Last Post: 16th Aug 2007, 04:37
  DVD fit on screenBy NHLroyrocks in forum Authoring (DVD)Replies: 6Last Post: 21st Jun 2007, 16:54
 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
				 Visit Homepage
				Visit Homepage
