I sometimes use Hotspot Shield
(www.hotspotshield.com)
which allows me to get to websites that would otherwise be unaccessible.
For example, at my location:
1)I have extreme difficulty going to Yahoo without Hotspot
2) Can never get to yahoomail or hotmail login screen between midnight and 7 am without Hotspot
3) Can never go to blocked (but harmless) websites such as www.4shared.com without Hotspot
4) Can never use Pandora music without Hotspot
5) During some times (maybe when a lot of people are using the internet), I nearly can't get to any website unless I use Hotspot.
My question is: Are there other VPN besides Hotspot? I have searched and can't find any other that work. If one day Hotspot doesn't work, I might as well just forget the internet. I thought websites were like roaches, if there is one, then there is another. Also, Hotspot has one disadvantage-- it only stays connected for several hours. After several hours, if will automatically disconnect. Once it disconnects (after several hour limit) between midnight and 7 am, or if it disconnects (after time limit) during a busy time, I will not be able to re-connect until the busy time is finished, or 7 am arrives.
Results 1 to 1 of 1
Using a Seedbox or VPN..what to choose...
By Moontrash in forum ComputerReplies: 2Last Post: 12th May 2011, 18:38 -
Wifi connection issue at a public hotspot
By usta in forum ComputerReplies: 3Last Post: 3rd Aug 2009, 21:12 -
VPN cuts off Network Authorization software - Please Help
By jimdagys in forum ComputerReplies: 1Last Post: 4th Apr 2009, 21:43 -
Do you use a VPN when connected to a free hotspot?
By freebird73717 in forum ComputerReplies: 6Last Post: 14th Aug 2008, 08:38 -
List of Hotspot finding sites
By ahhaa in forum ComputerReplies: 2Last Post: 12th Jan 2008, 21:19
