I have downloaded a number of Apple movie trailers some of which state they have 5.1 sound. I want to play the movies as part of an intro on my PS3 and retain the 5.1 surround. How can I either extract the AC3 from the .mov file or convert to m2ts and retain it that way?
Steve
I guess the audio is in aac 5.1 and not any ac3. If the ps3 supports aac 5.1 you can try remultiplex the mov to mp4 using Quicktime Pro or the free avidemux(use copy for audio and video) and save as mp4. See https://www.videohelp.com/forum/archive/changing-container-from-mov-to-mp4-in-bulk-t359449.html
If that wont work on your ps3 you can always reconvert using xvid4psp. -
Many thanks for the input Quicktime pro does not appear to maintain the 5.1 and avidemux gives errors.
However I came across SUPER which appears to maintain the 5.1 and converts to M2TS, however when I then use that file (converted by SUPER) as an input to tsmuxer to join a number together tsmuxer fails.
I resolved the issue by taking the output of SUPER into Sony Vegas and using that to create a new M2TS file (Sony Vegas would error on the original) which TSMuxer now works ok on.
It appears that Sony Vegas, Super and TSMuxer all have slightly different interpretations of what a M2TS should look like. But I found a way through albeit somewhat convulated. Steve
How to maintain color in mkv conversion?
By vato76 in forum Video ConversionReplies: 10Last Post: 15th Apr 2010, 11:53 -
Quicktime 5.1 to 5.1 ac3?
By piratehunter in forum AudioReplies: 18Last Post: 7th Jun 2008, 21:54 -
Quicktime DV conversion
By suchuwato in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 31st Jan 2008, 20:22 -
AC3 mono to AC3 2 channel conversion help
By efiste2 in forum AudioReplies: 1Last Post: 21st Jul 2007, 14:06 -
quicktime (.mov) conversion
By superstarx85 in forum Video ConversionReplies: 0Last Post: 11th May 2007, 05:10
