    Dec 2008
    plz,plz,plz help! i beg of you
    tell me how to set region code to A in bdedit
    im suicidal now after time spent tryin to figure out PSR20 command and hex system
    USA
    I would look through the Doom9 thread on the program: http://forum.doom9.org/showthread.php?t=125903
    Look to page two for this post by dmz01:
    Re-read the very first post of this thread that explains the structure of the movie object file. In that file look for a command that will read the last 8 bits of the PSR20 and then compare it to an expected value. If the comparison succeeds the player's region code and the disk's region code match, otherwise they don't. So at that point you have a branch where one side will let you continue on with the main feature, the other will give you a warning and terminate the playback. So all you have to do is replace all those commands with a single one that will always go to the main feature side of the branch.
    You might have to ask your question directly there if you don't find the info you need.
    And welcome to our forums.
    Dec 2008
    Thanks!
    but im actually trying to work around that message
    can't post there - 5 days wait for newly registered
    so if someone could give me a more detailed explanation, i would greatly appreciate that
    and i need to set it to region A, not region free
  4. Mod Neophyte redwudz's Avatar
    USA
    I haven't used that program, but I assume if you can modify the movie object file, you may be able to change the region code. Maybe another member here has some experience with it.
