  1. Does anybody know how to create dvd scene selection menu for the chapter selections? Thank you.
    Apr 2004
    Miskatonic U
    What type of scene selection do you want ? There are several built in menu templates that will do this for you.
    Personally, I create them from scratch because I don't like any of the built-in templates.
    Read my blog here.
    Oct 2006
    Canada
    Like guns1inger say, you have two choices. Either use template or make it yourself.
    If you want to do it yourself, use frames to insert them in menu and than appropriate picture into the frame representing each chapter. You can use text or arrows for link to next and previous menu, one also to go to main menu. Just look at some pro DVD how it is done.
    Than you can type text under each frame. You have a choice to link text, frame or picture within frame.
    Picture in the frame can be motion, but for starters just static picture should do.
    There is a good explanation in Help file which you can download from Mediachance web site for DVD Lab.
