I'm trying to convert an avi (divx) to NTSC DVD 4:3 with winFF but it stops almost immediately with an error:
"Seems stream 0 codec frame rate differs from container frame rate: 30000.00 (300
00/1) -> 23.98 (24000/1001)
Input #0, avi, from 'C:\firstvid.avi':
Duration: 00:00:09.98, start: 0.000000, bitrate: 689 kb/s
Stream #0.0: Video: mpeg4, yuv420p, 512x344 [PAR 1:1 DAR 64:43], 23.98 tb(r)
Stream #0.1: Audio: wmav2, 44100 Hz, stereo, 64 kb/s
Could not open 'F:\firstvid\firstvid.mpg'
I've tried changing settings but can't get anything to work. Is there a solution to this?
Sorry, I probably should have been more specific. I don't want the converted output to be in final DVD form with vobs and bups. The avi in question is a short video. It will eventually be part of a more complex DVD that will be authored with DVDlab pro.
The output file should be DVD compliant (mpeg2, proper resolution, and audio), but not in DVD format. I like winff because it has a half DVD option (352x480) that produces reasonable quality at small file sizes. Does the error indicate that winff can't convert it at all?
Is there a solution to this monotonically increasing dts winff error?
By yoda313 in forum Video ConversionReplies: 16Last Post: 10th Mar 2012, 07:34 -
WinFF and chcp 1252 Error
By gonwk in forum Newbie / General discussionsReplies: 3Last Post: 31st Dec 2011, 09:41 -
WinFF AppData
By Klagar in forum Video ConversionReplies: 1Last Post: 4th Oct 2010, 13:21 -
WinFF problem
By Eyedoctor2 in forum Video ConversionReplies: 2Last Post: 30th Apr 2009, 06:30 -
Winff problem
By Webfoot in forum Newbie / General discussionsReplies: 4Last Post: 26th Sep 2007, 21:25
