Anyone know the remote code for the trent 3351 dvd player? I am trying to get a dishnetwork remote to be able to control it. I went through a codescan correctly, but it failed to have the correct code (flashes 8 times rapidly after going through all the codes). I /think/ that Trent is owned or a brand of Astar, so maybe generic codes for that would work also.
Any help is appreciated.
Contact Dish or the maker of the Dish remote. They should have the latest codes.
Google is your Friend -
Dish will have the code for Trent? Wouldn't it be in the remote already then? I went through the remote code scan feature and it didn't work out.
"I am trying to get a dishnetwork remote to be able to control it." Sounds like you are wanting the remote code for your Dish remote so that it can control your Trent DVD player.
IF there is a code which will work, Dish should know.Google is your Friend
RJTech DVD Player Remote Code
By The Monkees in forum DVD & Blu-ray PlayersReplies: 0Last Post: 17th Apr 2010, 17:08 -
Need Remote control code for Desay DEVD player 5701 bought at Radio Shack
By PunkMaister in forum DVD & Blu-ray PlayersReplies: 0Last Post: 15th Aug 2009, 20:20 -
Portland PVD 1000 DVD player Universal Remote code Needed
By richco in forum DVD & Blu-ray PlayersReplies: 4Last Post: 20th Apr 2009, 17:17 -
VLC Player - Code Needed For Remote
By John_Jordan in forum ProgrammingReplies: 2Last Post: 15th Jan 2008, 22:13 -
Trent 9380 DVD Player
By moviebuff2 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 27th Dec 2007, 09:29
