    Feb 2008
    Italy
    Hello,i have a problem with muxman,I wont replace a subtitle in a dvd so i use first pcg demux then i use Subtitle creator for sup and finaly muxman...During muxman work i saw this message:
    Video decoder buffer underflowed 1 times.
    Check c:\muxman.log for details.
    Resulting DVD will probably not play smoothly.
    This is the log:
    MuxMan version 0.15R
    AAccepted audio D:\Mux\pcg\AudioFile_80.ac3
    Opened sub 1 file C:\Documents and Settings\sottotitoli dvd\definitivi\Subpictures_20.sup.
    22:34:04 Begin multiplex VTS01.
    Title Segment List
    Segment_1
    Encoded stream 20 is script stream 1.
    Maximum audio duration 426554 fields.
    Starting scene Segment_1_scn1 at 00:00:00:00
    SeqEnd at D50B.
    Starting scene Segment_1_scn2 at 00:00:00:12
    Starting scene Segment_1_scn3 at 00:04:07:03
    Starting scene Segment_1_scn4 at 00:11:45:03
    Starting scene Segment_1_scn5 at 00:20:03:16
    Starting scene Segment_1_scn6 at 00:26:13:17
    Starting scene Segment_1_scn7 at 00:31:56:03
    Starting scene Segment_1_scn8 at 00:36:03:07
    Starting scene Segment_1_scn9 at 00:42:26:14
    P-STD buffer underflow by 11346 bytes at 241606892, sector 429688.
    SeqEnd at 2DDDCE37.
    Starting scene Segment_1_scn10 at 00:45:15:00
    Starting scene Segment_1_scn11 at 00:47:19:17
    Starting scene Segment_1_scn12 at 00:53:20:01
    Starting scene Segment_1_scn13 at 01:02:27:00
    SeqEnd at 44984C05.
    Starting scene Segment_1_scn14 at 01:08:32:17
    Starting scene Segment_1_scn15 at 01:09:47:12
    Starting scene Segment_1_scn16 at 01:16:02:22
    Starting scene Segment_1_scn17 at 01:24:21:10
    SeqEnd at 5CFE5066.
    Starting scene Segment_1_scn18 at 01:32:32:00
    Starting scene Segment_1_scn19 at 01:33:31:17
    Starting scene Segment_1_scn20 at 01:39:49:03
    Starting scene Segment_1_scn21 at 01:50:00:12
    SeqEnd at 74593CE0.
    Starting scene Segment_1_scn22 at 01:56:43:00
    Starting scene Segment_1_scn23 at 01:57:32:15
    Starting scene Segment_1_scn24 at 02:03:37:17
    Starting scene Segment_1_scn25 at 02:10:25:23
    SeqEnd at 8D789349.
    Starting scene Segment_1_scn26 at 02:22:11:01
    SeqEnd at 8D78FCC1.
    Bytes remaining in buffer = 11346.
    Bitrate - avg: 2570289, min: 512000 (lba 878202), max: 14209969 (lba 429244).
    Shortest GOP has 10 fields, longest GOP has 24 fields.
    Fields: 426576, VOBU: 17621, Sectors: 1338408.
    Then i try to use Ifo edit but there is a same problem,but this time i can see the work and i see that in the second episode(there are 5 episodes)the video is blocked but the subtitles go...then in the 3° episode the video restart with sub syncro...
    this is the log of Ifo edit
    Starting new Multiplex Session
    Multiplexing Title 1
    Video stream: 0xE0
    Frame size: 720 x 576
    Picture rate: 25.000 fps
    Bit rate: 6000000 bps
    Vbv buffer size: 229376 bytes
    AC3 audio stream: 0x80
    nominal bitrate: 32768 Bps (256 kbps)
    Sample rate: 48000 Hz
    estimated multiplexed stream data rate: 6102000
    Vaid DVD program mux-rate: 10080000
    setting Video start-DTS: 21657
    setting Audio start-DTS: 25257
    Multiplexing...
    setting Video dely: 21657
    setting Stream dely [0x80]: 25257
    setting Stream dely [0x20]: 25257
    Stream 20: data will arrive too late.Current SCR: 241528978,stream DTS:0
    Stream 20: data will arrive too late.Current SCR: 241614994,stream DTS:0
    Stream 20: data will arrive too late.Current SCR: 241658880,stream DTS:0
    Stream 0x20 completed,Frames:1706
    Stream 0x80 completed,Frames:266595
    Stream 0xE0 completed,Frames:213287
    Multiplex completed at SCR: 767770477
    Video stream statistic: 0xE0
    Average bitrate: 2225600 bps
    Peak bitrate: 5603200 bps
    Stream 0xE0 buffer min: 11,max: 220590
    AC3 audio stream statistic: 0x80
    Audio stream length: 272994304 bytes
    Syncwords: 266596
    Stream 0x80 buffer min: 19587,max: 56163
    Stream 0x20 buffer min: 618,max: 59363
    Multiplex status: Buffer under-runs detected!
    Multiplex finisherd!
    Where is the problem? help me..thx
    Sorry for my bad english....
  2. Muxman won't produce a playable DVD, of course, but IFOEdit, even with the message, will. My suggestion is to ignore the message that IFOEdit gives and to use the IFOEdit authored DVD. The chances are excellent that you'll never notice anything wrong when playing the DVD.
    Feb 2008
    Italy
    Ok thx.But now i have an other problem, when i check the subtitle file(str) with Arpa Kolla with video of the dvd,the sub are perfectly syncro..When i mux them the subs are out of syncro (3 o 4 seconds)why?
  4. I couldn't tell you as I don't use SubtitleCreator to make SUP files for DVD. However, add in the delay (the amount they're out-of-synch) to the SRT file using SubtitleCreator before making the SUP file.
    Feb 2008
    Italy
    There is a good program that works better of SubtitleCreator?What program do you use to convert sub?
  6. I use MaestroSBT to convert SSA text subtitles to SST subtitles which Muxman accepts. That doesn't help you with your problem, though. I'm not saying SubtitleCreator doesn't work well, and I don't know the cause for the out-of-synch subtitles after authoring with Muxman or IFOEdit. All I was saying was that you can easily fix the problem before making the subtitles.
    You can also fix the out-of-synch subtitles in the completed DVD using DVDSubEdit. You'll want section 3.2 of the manual:
    http://download.videohelp.com/DVDSubEdit/UserManual/helpfile.htm
