    Dec 2008
    Looking for an implementation of the FFMEPGX app to take a Flash input stream and convert to H.264 in near real time.
    Something like: Read in a Stream ID from and XML file in a monitored directory (or periodic database query), begin converting into stream that can be accessed via temp URL until the input stops. This would either be a modification of the basic software or instructions of how to do it with what I have now.
    Don't expect it for free of course.
  2. Member Soopafresh's Avatar
    Jan 2004
    I really don't have the technical skills to help you out, but feel free to get some ideas from this Loop Transcoder script I threw together. I set it up to wait for .flv files to process.
    Run Loop_Transcoder.bat, then drag an flv file into the same folder. It'll find the file then transcode it to h264 MP4
    loop_transcoder.zip
    More professional would be to use something like Procoder or similar, which uses a Watch Directory to automatically process into your desired format.
    Dec 2008
    Sweet!
