In Adobe Premiere Pro 1.5, in the media encoder, under pre-encoding task, you can select "scale".
Under audience, you can enter a frame size.
What is the difference between these two?
I could be wrong, but I think 'scale' changes the output resolution of the actual video itself, while 'frame size' only changes the display height and width (ie., it results in a letterbox effect, causing black bars to appear without the video resolution actually being altered). I just checked in Premiere Pro 2.0 and they don't seem to have these settings laid out the same. Which video format are you exporting to?
I am exporting to WMV. The purpose is to upload to YouTube, which has a size of 640 x 360 (16:9).Originally Posted by Hawkes
My source is miniDV NTSC and shoots in 720 x 480 (1.5:1 or 3:2) even in widescreen mode.
Real Player and QuickTime plays my videos at 720 x 480, which seems to squish the video horizontally.
Windows Media player plays it at widescreen.
In QuickTime, it tells me that my video size is 853 x 480 (close to 16:9) <--- this is the video captured by premiere without encoding (when you capture it creates a .avi video file). -
wmv is a highly compressed final viewing format which youtoob will happily re-encode yet again...highly compressed formats don't take kindly to re-encoding
maybe try uploading your .avi and see if youtoob's software displays it correctlyYouTube accepts a wide range of video file formats such as .WMV, .AVI, .MOV, and .MPG transferred from most digital cameras, camcorders, and cell phones. -
you need to use an editor like vegas pro 8 that has settings for DVavi wide pixel mode. then you can have it encode to anything and the result will be in widescreen. for youtube i'd go with 1280x720p h264 5-10mbps and aac audio. that way you'll get the view as HD link and a higher quality video posted.
Adobe Premiere Import image size
By Graemey in forum Newbie / General discussionsReplies: 18Last Post: 21st Mar 2011, 18:16 -
the effect of scaling to frame size (PP)
By metathran in forum EditingReplies: 4Last Post: 18th Feb 2010, 14:59 -
DVD to Adobe Premiere Frame Flicker Problem
By bighurt in forum Video ConversionReplies: 2Last Post: 6th Feb 2009, 13:32 -
Adobe Premiere 1.5: Adobe Media Encoder: Frame size and scaling?
By vid83 in forum EditingReplies: 2Last Post: 30th Nov 2008, 04:17 -
Video size too small in Adobe Premiere
By sadievladimir in forum Newbie / General discussionsReplies: 12Last Post: 23rd Mar 2008, 11:15
