i have sucessfully ripped a dvd onto my hard drive. i have sucessfully converted the dvd to one big mpg file. the files plays perfectly on my computer. now i need to cut the file to fit it on a couple of cdr's.
i have been trying to use tmpgenc and keep getting an "address error". i have tried dvtools and the output from dvtools will not play. can someone please help me overcome this obsticle ? i have the hard part done....i just need to sucessfully split the file, but i cant seem to be able to accomplish this.....
many thanks to all that reply !!
i'm using tmpgenc cutting function under MPEG tools. i assume you used that too? make sure you select the video type when u r using tmpgenc's cutting function. if it's SVCD, you should choose video type of SVCD vbr before you start cutting, otherwise, it might mess up
MPG movies show shorter time then actual... help needed
By wolf_ast in forum ComputerReplies: 5Last Post: 30th Mar 2011, 20:52 -
DVD to MPG/AVI/H264 for editing - desperate help needed
By BertRito in forum Newbie / General discussionsReplies: 19Last Post: 17th May 2010, 23:46 -
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 13:51 -
toast won't do wav, so using mpg file instead of m2v file gets round that?
By jboyd in forum ffmpegX general discussionReplies: 12Last Post: 16th Nov 2007, 14:08 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 17:52
