first off i'm rather incompetent with computers so bear with me
i'm trying to play a dvd using VLC, it's from europe but it plays fine so the region isn't an issue
when the dvd is still in the menu screen and i go to "video" "subtitles track" it shows track 1 and track 2
i'm assuming one of these "most likely track 2" are the subtitles
but when i play the dvd and go back to those options it is on "disabled" and track 2 has disappeared, there is only track1 "when i click on it no subtitles" and disabled
(the dvd does have englsih subtitles on the disc)
also i can just push play and it goes but if i open it using "media" "open disc" and look at the file in the E drive it's called VIDEO_TS and subfiles are VTS_01_0.VOB etc when i go from "disc" to "file" there is a "use subtitles file" box i can check but i'm assuming you only use that when it isn't an actual DVD but rather a file, like a torrent file you've downloaded so you can put them in the same folder to get it to work.
sooo any idea why the track 2 disappears when the movie is playing and is that in fact how i would get the subtitles to play or is there another way?
Try another free dvd player like media player classic or kmplayer and see if the subs work better.
VLC Video Player won't open subtitles
By snafubaby in forum Software PlayingReplies: 2Last Post: 14th May 2011, 23:47 -
Samsung HD video won't play in VLC, but will in Win 7 WMP... why?
By wild_fan in forum Software PlayingReplies: 3Last Post: 18th Dec 2009, 13:33 -
AVI files won't play in anything but VLC
By zanos in forum Newbie / General discussionsReplies: 6Last Post: 13th Dec 2009, 22:07 -
Demuxing Smartripped VOB with VobEdit06... M2V won't play in VLC?
By Iceblade in forum Video ConversionReplies: 12Last Post: 15th Oct 2007, 23:30 -
divxmuxgui would write subtitles to play on wmp but not on vlc
By greendesert in forum SubtitleReplies: 1Last Post: 28th Sep 2007, 05:03
