I have hundreds of video clips in a project, yet it seems the only way I can add VideoFX (such as color correction, etc.) is one at a time. The changes don't stick when I adjust the variable settings after highlighting a bunch of clips and dropping a video effect on them.
Though I can sometimes add an effect to several clips using only the default effect setting. I can't adjust the important varible settings on the many clips at once. Though this is very simple to do in versions of Pinnacle Studio.
Is there a way to add one type of effect to lots of clips at once and adjust mass variable settings (such as contrast levels, brightness levels, etc.) at once too? Instead of one by one for each clip?
Thanks!
If you all your clips are on a single time line (track) then you can add the effects as Track FX. This will apply across any clip on the track at the time, or added to the track later on. If you have multiple tracks, set up one the way you want it, then save the chain as a package so you can load it onto other tracks.
Read my blog here.
^ I second that. Making good use of effects chains is a HUGE timesaver.
Sony Vegas Pro - Importing clips from another project
By ClownInBrown in forum EditingReplies: 8Last Post: 18th Apr 2011, 19:43 -
Head swap in a video using Sony Vegas Pro - is it possible and how?
By Nicole2011 in forum EditingReplies: 6Last Post: 19th Feb 2011, 16:52 -
Sony Vegas Pro 9: Batch Render Clips Separated by Markers
By mltwitz in forum EditingReplies: 0Last Post: 5th Apr 2010, 15:41 -
Sony Vegas Pro 8 ... transitions application on multiple video clips ???
By holeepassion in forum Newbie / General discussionsReplies: 3Last Post: 20th Feb 2010, 01:04 -
Capturing a still image from video in Sony Vegas 8.0 Pro
By ruffryd in forum EditingReplies: 2Last Post: 29th Oct 2008, 16:49
