Hi everyone, I hope this is posted in the right place.
I have a surveillance video file that i have to zoom and enhance at a certain frame, so that i will be able to see a relatively small number.
The specs (according to GSpot 2.70a):
File type: ASF (.WMV)
Mime type: video/x-ms-asf
Sys bitrate: 622 kb/s
Codec: WMVP - Name: WMP v9 Image
Length: 2:03.701
dimensions: 320 x 240
sar: 1.333 (4:3)
I hope i included all the right information, as i am a total newbie to video editing.
Is this at all possible? and if so, how? using which software?
Thanks a lot guys.
	Honestly, the chances of getting any real detail out of a clip this small and compressed are very remote. You simply don't have enough real data to play with.
 However if you want to try, I would start with this : http://www.thedeemon.com/VideoEnhancer/
 If it cannot open your file then you may have to use avisynth to load the file into video enhancer.Read my blog here.
	Also note that WMV compression threw out all the small details so there's not much left to work with. You'll end up enhancing the video compression artifacts.
  Zoom H1By Mac_Newbie in forum AudioReplies: 4Last Post: 5th Dec 2011, 22:40
  Video techniques - shaking zoom in and zoom out effect?By Mylo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 12th Oct 2011, 12:08
  Need Software that can Zoom inBy xxxThiefxxx in forum Newbie / General discussionsReplies: 7Last Post: 26th Feb 2011, 23:10
  Zoom in on an image.By RyanC in forum Newbie / General discussionsReplies: 9Last Post: 8th Aug 2008, 05:45
  How do i make a zoom????By hostheking in forum EditingReplies: 5Last Post: 15th May 2007, 22:40
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
