  1. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    I'm dealing with existing authored sets of DVD files (complete
    VIDEO_TS folder ready for burning) located on my hard disk - 20 in all!
    What I want to do is modify the existing parameters so that if no human action is initiated , ie make a selection
    from the existing menu within "n" seconds the DVD commences to play the first title.
    I suspect I can vary the parameters with a program like PgcEdit or similar ? But!!! I
    don't want to re-author the DVD's - there are simply too many to do and maybe an additional feature would be a
    batch file can run to make the adjustment for the whole collection?
    many thanks
    Feb 2004
    Australia
    In pgcedit, locate menu in left hand pane you wish to modify and double click (default) to show pgc editor window
    Change cell time (max = 255 seconds)
    Cell command box to 1
    Click ok
    Back in main window pane on right, left click "cell commands" down below and then right click for context menu, select "add after"
    The command entered for project will be determined by navigation structure, basic would point to "jumpvts_tt" where titles are under a single vts title set
    So after X seconds, it jumps to start of chosen title ... tada
    As for batch method, unless all titles are authored to the same specifics then that's a "no"
    If yes, then pgcedit dose support "export" and "import" of commands ... for everything else there's autoit
  3. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Thanks very much for the prompt and detailed reply - very much appreciated
