    Dec 2008
    Puerto Rico
    Ok so, I'm looking for a fisheye lens, that fits my camera, the problem is that my camera is a Canon ZR950. Anyone knows if they even make a fisheye lens that fits my camera? This is my camera.
    South Africa
    Looks like your camcorder doesn't have a thread to allow you to screw on additional lenses/filters. So I suspect you will struggle with this.
    If you're lucky, you might be able to get one of these to work:
    Raynox QC-303
    http://www.amazon.com/Raynox-303-QC-Converter/dp/B00009UTK3
    But it is unlikely that it will not attach properly to your camera. I would try to take the camera to a store and see if it does fit. Alternatively, you could use a lot of duct tape to stick it on. Which would probably not be the best solution.
  3. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Call B&H Photo. They would know.
    http://www.kiva.org/about
