    Jul 2001
    How can I make VideoLAn my default video player?
    I can't find any command to "make it so,"
    Even the VideoLAN home page did not help.
    I know what I first set it up it was the default player, but, sometime afterword Window's own media player took over (and refuses to play anything at any time) the duty.
    And I am sick and tired of manually opening VideoLAN for each and every video.
    THanks for any help.
  2. Member zoobie's Avatar
    Feb 2005
    Florida
    right click on a video file>open with>select from list>vlc>then check the 'always use this program when playing this filetype'
    Jul 2001
    Does not work
    Doing so only starts media player which then promply opens up a error window.
    I know what you are thinking of, but, I don't want to go and do this for each and every file format.
    There must be a command in VLC (just as there is in MediaPlayer or QTW) to make it the default player.
    I wish I couild remember it
  4. Member zoobie's Avatar
    Feb 2005
    Florida
    then try going into each player and checking/unchecking the associated files
    sounds like wmp is over-riding everything
  5. Mod Neophyte redwudz's Avatar
    USA
    When you installed VLC, you should have seen an option to 'Associate with files' or similar. That puts VLC into the R Click menu when you select a video file. But WMP will still try to butt in occasionally. What zoobie said for that.
  6. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Are you still using Windows 98 as shown in your computer profile?
    http://www.kiva.org/about
