When connection of the DV and PC with a FireWire IEEE 1394 cable such as 4-4 pins, there is no specific software needed. I can capture the video by any software such as Windows Movie Maker. However, the Windows Found New Hardware Wizard pops up if the DV is connected with pc by the USB cable. If I cancel the Wizard, the error messages will display the video capture device was not detected, though the Windows Movie Maker is installed. Does it mean any connection with the USB cable between the DV and PC must have that USB specific capture software instilled first? Is it possible to capture the video through the USB cable without additional USB software installed or every USB connection must have the USB specific software installed first?
usb cam connections are usually only for copying still pictures. DV and HDV can only be transferred via firewire.
you can use a USB interface to capture video, but you'll be sharing transfer bandwidths with every other USB device that's connected to your machine. Firewire is much more reliable because of its increased bandwidth.
AG-DV1000P -- Firewire Connection Crapped Out??
By jbd5010 in forum Capturing and VCRReplies: 6Last Post: 6th Apr 2011, 12:34 -
Firewire Connection - how to secure??
By motown01 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 23rd Nov 2009, 14:39 -
sony camcorder firewire connection
By rizvii in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 7th May 2009, 00:23 -
firewire connection without sound
By m baqar in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 25th Apr 2008, 09:10 -
Testing Camcorder Firewire Connection
By wacole in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 13th Nov 2007, 11:41
