Hello,
I am running Windows XP and have already upgraded to a 250GB drive some time ago in addition to two external hard drives. I added the ATA card when I added the 250GB drive. Will the 1TB be a straight swap or do I need to upgrade anything else? Thanks!
Results 1 to 13 of 13
if your comp can address the the full 250 it will also be able to use the 1tb. it just requires xp with >sp1.
you may be able to use both if the ata card came with a 2 drive cable. make one master and one slave.--
Assuming a SATA drive and spare SATA socket, just plug it in, partition and format.
one would hope the drive is ata since he mentions adding the "ata" card.
I don't know of any PATA(IDE) 1000GB(1TB) HDDs, so I assumed SATA. Both are 'ATA'.
Thanks as always, gentlemen. I know I needed to add the card when I added the 250GB and 'upgrade' to SP1. So I'm good to go?
I usually go with Seagate. What do you guys think about this?
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148274 -
There are bound to be better specials but it looks good...good 5 year warranty...good dealer...good price...good shipping...good performance with the jumper removed...if seagate's your thing, go for it
It's this mentality that manipulates the masses.Be the first on your block with a Terabyte drive
If someone had said gamers would spend hundreds if not thousands of $ playing games 20 years ago, they'd have been locked up -
problem with terabyte is that when your wife looks at the stuff on it and throws it out the window you are SOL....
I use two 500 GB'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie -
Thanks, zoobie.
Ron, I keep that stuff on my site where she can't get to it.
If somebody would like to chime in I have another question.
Do I need to upgrade the card for the new hard drive or am I OK with the one I currently have? I'm not sure of the specs but I got it a few years back to add the 250GB.
Thanks! -
Probably not. The older adapter card may be a SATA 150 card, but it would still be compatible with a SATA 300 drive. I doubt you would notice any obvious speed increase with a SATA 300 adapter.
Other than that, plug it in and see what happens. You will need to format and partition it, but the OS can do that.
Thank you for taking the time out to answer my questions, I appreciate it.
Looking for a new 1TB internal drive. Seagate too many issuses now?
By Denvers Dawgs in forum ComputerReplies: 9Last Post: 12th Jun 2010, 07:37 -
Does 1TB hard drive works on Philips dvp 5990/2
By waefwaeefwaefw in forum DVD & Blu-ray PlayersReplies: 9Last Post: 8th Dec 2008, 21:52 -
Compare 1TB Hard Drive - Which One to Choose
By mn072065 in forum ComputerReplies: 5Last Post: 21st Apr 2008, 13:18 -
Need advice on 1TB Hard Drive Please
By mn072065 in forum ComputerReplies: 15Last Post: 26th Mar 2008, 17:02 -
1TB hard drive only $260
By piano632 in forum ComputerReplies: 32Last Post: 4th Oct 2007, 20:45
