Try DVDFab and copy Ultra HD Blu-rays and DVDs! Or rip iTunes movies and music! Download free trial !
    Sep 2008
    Belgium
    Hi,
    I am working on a commercial project looking similar to the "ipod" publicity with people dancing on a flashy background (with "silouhettes").
    Something that i though not that difficult to do in AE, and indeed everything works fine, i create a animated mask and my silouhette is perfect.
    But there is a problem ... let's say i have my silhouette of a woman running in a resolution of 1920/1080, how can i zoom in until i only see the head (or anypart) without loosing the quality of the edges of my silhouette ?
    The masks are vectors, so there should be a way to transform the mask into a nice silouhette, but everything i tested (transform, trackmate and some other tips) result in a blury edge. The solution could be to start a giant mask and dezoom ... but i am pretty sure there is an other way =)
    In fact i would like to transform my mask into a silouhette with clean edges (vector quality) ... and zoom in/out without losing quality, is that possible ?
    Hope somebody can help, and sorry for my english
    Kiwi
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    That is the way I always do it. I use 1920x1080 source masks for SD and 4kx2k up for HD when I plan to pan and zoom into the frame. Same goes for graphic elements.
    http://www.kiva.org/about
    Sep 2008
    Belgium
    Thanks for answer, i ll do it that way then.
    If anybody else has a better solution ... you can post here
