A DVD movie was copied and saved in the DVDFab folder in My Documents by the DVDFab. By search the DVDFab folder and its subfolder movie could be seen in My Documents. However, there is no DVDFab folder by clicking Start\My Documents. Do you know how to display all hidden folders in My Documents?
'Control Panel>Folder Options>Views>Display hidden files and folders'
Got it. The Folder Option is In the Classic View. Thanks.Originally Posted by redwudz
If you want to unhide that folder but hide the others, right click the folder and select properties. Remove the checkmark for the hidden property and hit apply and then ok.
That folder will be permanently visible now.
At that point, you can hide the other folder again, if you want.Believing yourself to be secure only takes one cracker to dispel your belief.
Help with documents please
By t_jay17 in forum ComputerReplies: 7Last Post: 9th Feb 2009, 22:37 -
Scan/Archive my documents and invoices using scanner
By ha13may in forum ComputerReplies: 0Last Post: 26th Aug 2007, 17:18 -
DVD with movie and some data(ie documents)
By hellhole in forum Authoring (DVD)Replies: 4Last Post: 20th Aug 2007, 01:17 -
The conversions to full standard HDTV defined in official documents
By T12345 in forum DVB / IPTVReplies: 2Last Post: 26th Jun 2007, 08:32 -
searching multiple pdf documents in one folder?
By bballnut in forum ComputerReplies: 6Last Post: 18th Jun 2007, 00:15
