How do i disable the G15 lcd display, ive tried disabling it in the logitech LCD manager, but then once i close and reopen MPCHC it just starts up again.
Btw, this is about the Logitech G15 keyboards LCD display.
I don't know the answer to your question. But was does that display do/show? Is it just that the backlight is distracting while viewing movies?
it shows info on the screen, volume level, date, time, file name, and a time bar to show u how far into the video u are.
distracting yes, very, annoying as hell, especially since i dont need it.
And it sucks cuz i cant turn it off
Is it only MPCHC that's causing the display to come on or will any media player do the same? I suspect the keyboard software installed a DirectShow filter that you might be able to disable with Radlight Filter Manager or some other filter manager.
Right click on logitech g-series keyboard profiler icon in the right corner of your taskbar and choose gamepanel manager,then click on programs and uncheck mpchc in all available boxes.Lots of programs are designed to interact with g-15 on a software lvl so filtering wont help.
MPC won't display video on second monitor.
By zeek543 in forum Software PlayingReplies: 4Last Post: 19th Sep 2013, 21:21 -
MPC won't display on secondary monitor
By Monarch1st in forum Software PlayingReplies: 2Last Post: 17th Feb 2012, 12:11 -
Softsub in Avi Does Not Display In MPC
By Docoptik in forum SubtitleReplies: 2Last Post: 6th Nov 2011, 12:00 -
Disabling On-Screen Channel-Change Display (Scientific Atlanta Exp 3200)
By jillsy in forum DVB / IPTVReplies: 3Last Post: 15th Dec 2010, 00:12 -
How to get MPC to display images?
By SignedupGuest in forum Newbie / General discussionsReplies: 2Last Post: 4th Oct 2010, 14:31
