Tried to install the latest version 1.07 and my Norton virusscanner gives a viruswarning..a trojan horse. Running the program it gives me the same message and the advice not to use it at this moment...does anybody had the same problem..can I ignore this message or not???![]()
Results 1 to 9 of 9
I wouldn't ignore it! Where did you DL it? They might have an infected file.
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
The warning in VCDEasy comes when I check for a new version...it says "Norton Antivirus reports that cygz.dll from Gnu VCD Imager is infected by a trojan horse. I am not sure it is true, as it does not have the symptoms described in...'symantecsite'... wait to things get clear.."
I downloaded the file from two different sites, and it gives this message everytime when I check for new versions... -
Symantec has apparently issued a new virus definition set this morning that fixes this problem. You may need to force an update in NAV to get the new definitions. I tested it on cygz.dll and it no longer detects a trojan
when I run the virusscanner it doesn't detect anything, only inside the progr. there is a warning....
Check out http://servicenews.symantec.com/cgi-bin/browse.cgi?group=symantec.support.generic.virus.general and put "cygz.dll" in the search box. NAV's definitions that came out yesterday caused a bit of a flurry. They have issued a corrected set today. VCDEasy's warning also says to get the new definitions.
I had VCDEasy 1.04 and it was working perfect. Then for some reason all my burnt VCD's started showing two small views at the top of the screen. I downloaded VCDEasy 1.07 to try to correct this problem but it is still the same. Could this be associated with a virus or has anyone else had this problem? Does anyone know the cure?
Thanks for any help. -
There is no virus.
NAV is in error and this is fixed with the newer definitions.
Regards.Michael Tam
w: Morsels of Evidence
Administrator Privilege to Run VCDEasy
By asifmcp in forum VCDEasy GeneralReplies: 2Last Post: 8th Jan 2011, 04:48 -
VCDEasy doesn't work in Vista...
By iThinkYouBrokeIt in forum Authoring (VCD/SVCD)Replies: 14Last Post: 26th Dec 2010, 20:20 -
Burning with VcdEasy
By gkma01 in forum Authoring (VCD/SVCD)Replies: 6Last Post: 19th Sep 2008, 20:00 -
Problem with creaing Menu in VCDEasy
By haris in forum Authoring (VCD/SVCD)Replies: 5Last Post: 16th Mar 2008, 08:17 -
How will I make an AVCD using VCDEasy?
By zeldAIS in forum VCDEasy GeneralReplies: 1Last Post: 4th Aug 2007, 15:13
