I have a monitor with a dvi-d output and a video card with a dvi-i input, will a dvi-d cable work or do the monitor and card need to be the same?
Yep, you can use a dvi-d cable to connect from the dvi-i output to dvi-d.
DVI-I means that it supports both analog and digital output.
Plug DVI/HDMI adapter to DVI video card?
By Stealth3si in forum Media Center PC / MediaCentersReplies: 25Last Post: 23rd Dec 2010, 19:32 -
Question about DVI-D & DVI connections ?
By VEBouto in forum ComputerReplies: 2Last Post: 27th Oct 2010, 08:28 -
DVI - HDMI - DVI problem
By rbjt in forum Media Center PC / MediaCentersReplies: 0Last Post: 4th Aug 2009, 23:14 -
Computer DVI output to TV DVI input
By superdud1400 in forum DVB / IPTVReplies: 12Last Post: 13th Jul 2008, 09:44 -
DVI-D cable in DVI-I slot-possible? Quality loss?
By bigshotceo in forum DVB / IPTVReplies: 1Last Post: 21st Dec 2007, 06:49
