i've made several .m2ts files w/ tsmuxergui that i can not get sound out of, even w/ VLC player. two examples of the audio streams included are DTS, and AVC+HD. tried to play on pwrdvd first which i thought would certainly be able to decode everything, then i installed coreavc so i could play on wmp, and same thing, no audio, also w/ VLC. i've checked the .m2ts files w/ mediainfo and there are indeed audio streams present.
why won't they play??
thx,
rlr
i didn't install the separate ac3 codec, am using ffdshow.Originally Posted by Baldrick
i have now downgraded to 32bit vista ult, and have a nice clean install, with some key codecs (still working on some), but the files i created before are playing much better now, ac3 and dts is fine in wmp, but won't play True HD, looking for a codec for that now, if it exists.
thx
Why do some m2ts files play on PS3 while others in the same format don't?
By chrvi in forum Video ConversionReplies: 7Last Post: 12th Mar 2012, 14:31 -
I can't play back .m2ts files with DTS audio
By Quadcam in forum Blu-ray RippingReplies: 3Last Post: 24th Nov 2011, 17:31 -
How to convert m2ts files to mp4 files with sound
By diets in forum Blu-ray RippingReplies: 8Last Post: 18th Jan 2010, 12:17 -
WinDVD 9 Plus BlueRay will not play m2ts AVCHD files
By deejay.2001 in forum Software PlayingReplies: 2Last Post: 14th Jul 2008, 09:33
