I've read DVD Players' Compatibility list and this standalone dvd players seems to play Svcd. So I've burned one Scvd with Nero 5.5.3.5 but it doesn't work on my players. Is it really compatible with this format? How can I get a compatible svcd to play with Pioneer 717?
Thanks.
Pat
What exactly does your player do when you try to play one of your SVCDs?
As a good guide to whether or not your 717 can play SVCDs, download the sample clip from this site and burn it with Nero5.
If it works, as it did when I was trying to sort out my dv444, then you need to change your encoding settings.
Let me know how you get on ......
Sue xxx
You are very kind Sue.
When I insert the disk in the player it points out the writing " cd " and playing it the time of the track flows but there is no video or audio (they are present two tracks).
I will try to do what you have told me however but as I have to use Nero?
Have I to burn like vcd (cd) standard? Should I use Mpeg2 or Mpegav, entryvcd or entrysvd?
Thank you.
Pat -
Hi again !
In my experience, Nero5 is a good place to start.
It's not too complicated and burns very compatible disks - even if it does complain when you give it even a slightly 'non-standard' MPEG file!!
Have you tried creating both VCD (MPEG1) and SVCD (MPEG2) disks?
For the purposes of this test, make absolutely sure you create a standard VCD (or SVCD). See the links on the left for all the bitrate/resolution info you'll need <<---.
Personally, I had no problems with VCDs on my DV444, but when it came to SVCD ........ oooweee......... WHAT A NIGHTMARE!!
Finally sorted it though, so if you'd like a copy of my SVCD template (for TMPGenc!) let me know.
Laters,
Sue xxx
To Sue,
Happy to receive your tmpgenc template.
My email is julesclaes@skynet.be
Many thanks -
Hi Sue,
I've burned the sample file downloaded from this site with Nero. I've tried to play it on my pioneer 717: it didn't work...!
Maybe my player isn't compatible with svcd. Is there another chance to test my player?
Anyway send me your template, I'll made another try...
Thank you
Pat.
patdb69@yahoo.com -
Sorry to hear you're having so many problems Pat ......
.... anyhow, the template's on it's way to ya ........
..... Have you tried different burning software? (like VCDEasy, VCDImager etc etc) ......
Good Luck,
Sue xxx
Pioneer DV-3022KV
By azfarhus in forum DVD & Blu-ray PlayersReplies: 11Last Post: 24th Mar 2012, 04:37 -
Pioneer DVR
By vcd4me in forum DVD & Blu-ray RecordersReplies: 20Last Post: 25th May 2011, 01:33 -
Pioneer DV-F727
By captainneek in forum DVD & Blu-ray PlayersReplies: 0Last Post: 16th Jan 2010, 14:59 -
Pioneer DVR-112 seems to stop my Pioneer DVR-115 from being recognized
By Thommo1978 in forum DVD & Blu-ray WritersReplies: 9Last Post: 3rd Feb 2008, 07:02 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 07:18
