Results 1 to 11 of 11
    Dec 2006
    Hi,
    I am looking for a good reliable AMV converter that will convert any video format to AMV format.
    Can anyone point me to a program like this? Free?
    Any help would be greatly Appreciated
    Thank You
    Find something here:
    http://www.google.com/search?hl=en&q=convert+amv+freeware&btnG=Google+Search&aq=f&oq=
    Cross-reference results with the list here:
    https://www.videohelp.com/tools
    Then you'll find something that does what you want, and whether it is suggested.
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    The only AMV convertor that I have found that produces files playable on one of these horrible players is the one that ships with the player. There is a converter based on a customised version of ffmpeg, but none of the files it produced, using any combination of settings, would play on the player in question. Only the software that shipped with the player produced playable files. This seems to be a common problem.
    Anyway, the program is called BAMVC, and can be found here : http://www.nonags.com/software.asp?ID=3297
    Read my blog here.
    Dec 2006
    Thanks lordsmurf
    I did the Google thing,that's why I posted here as there was a bunch of different programs. I hadn't seen that there was a list here to cross-reference with...time to do my homework.
    guns1inger,
    Not everyone can shell out a couple hundred for a player so this one will have to do.
    I do have the software that came with the player I just assumed that as with all software that comes with things there has to be better available.
    Thanks for the help guys
    Its Appreciated
  5. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Originally Posted by LCE
    guns1inger,
    Agree entirely, which is why I speak from experience. I could not get BAMVC to produce a file that would play on my daughters player. The software that came with the player works, but isn't great. I find that I end up having to write avisynth scripts to get the software to encode many formats, and to get the correct aspect ratio in the output as well.
    Read my blog here.
    Dec 2006
    guns1inger,
    Experience sometimes comes at a price and at other times from somebody else
    I messed around with the software that came with the player tonight and couldn't for the life of me get it to work(wouldn't convert at all) and the instructions were so poorly written they were of no help.
    I'll check out the link you gave and see if I can get that to work.
    Any more experience is always welcome
    Thank You
    Les
  7. im having same problems the shipped version does it but audio is ALWAYS out of sync - i see it uses my K-Lite ffmpeg codec when doing it perhaps if i used another codec like divx... thing is i still want it 4:3 which it also doesnt give the option of - so i would have to convert AVI-to-AVI as 4:3 then AVI-AMV (but using software/codec that will keep audio in sync)
    Apr 2003
    michigan,usa
    I also have a player that uses the AMV format. I found a freeware program called Bytessence MPxConverter 1.1 .
  9. I'm a MEGA Super Moderator Baldrick's Avatar
    It looks similar to the tool that guns1inger posted above.
    Bytessence MPxConverter:
    http://www.softpedia.com/progDownload/Bytessence-MPxConverter-Download-98790.html
    Bytessence AMV Converter
  10. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    Yep, i posted that same converter in snadge's OP.
    After searching and searching and trying quite a few converters that one has always produced excellent working files for my cheapie mp3/video player.
  11. that MPx converter finally worked.... thanks
