    Dec 2008
    Canada
    Hi
    I'm obviously missing some fundamental concept here. I'd like to have a button that will play the movie (or open a submenu). I want this button to be animated. However I can't seem to get the animation button to show. Its always disabled.
    Suggestions??
    Aug 2006
    [s:df713f3c5b]Not showing within GFD, or not showing when the DVD files have been authored?[/s:df713f3c5b]
    OK, I just figured out what you mean. Select "Project" on the Settings Menu, and on the "General Settings" tab, check "Animated Menus." Finally, click the "Save" button.
    Dec 2008
    Canada
    RESOLVED. I had to install some additional programs. (avisynth, etc).
    Maybe I didn't need to install anything, just follow the steps above
    Aug 2006
    No, you need avisynth installed too for animated buttons/menus.
    The setting for animated menus may be turned on by default when GFD is installed. I don't remember. I don't use many animated buttons/menus for my projects, so I unchecked "Animated Menus" in my Permanent Settings.
