I added a comment on another thread but I probably should have started a new one, so you may see this question someplace else. Has anybody had any problems using a Pinnacle Studio Moviebox Plus for a/d conversion? Not Pinnacle software.
A few years ago I did a tape-to-dvd conversion project that worked out well. I used borrowed equipment & after alot of trial & error got things rolling & had several good DVDs. I took notes about some of the problems & how they were resolved but of course I can't find those notes now. The audio & video outputs from my vhs player went into the analog inputs of a borrowed Sony camera. The output of the camera went into the firewire connector on the PC. Adobe Premier was used to capture. Somebody recently asked me about this & I suggested using a Canopus a/d converter & I was asked "Pinnacle Studio Moviebox Plus is less expensive. Can't I use that for the a/d conversion?". So I don't know, has anybody used that ? Just for the hardware not the software. The quality of the tapes is vhs home movies recorded on hand held consumer cameras of various brands.
Thanks,
Jim
Hi Jim, I've got a Pinnacle MovieBox that I bought for transferring video off my old 8mm camcorder. I don't use it anymore now that I have Firewire and HDMI-capable cameras, but while I was using the MovieBox I don't remember it giving me any major headaches.
It's got RCA and S-Video ports with the ability to transfer to PC via USB or Firewire, so it should fit your needs.
Yes, the software part of it... haha... is a little lacking.
Pinnacle has a nice capture utility but the software itself has given me big problems and even has a bit of a reputation for giving computers the old knockout blow. That aside, the MovieBox interface should do the trick.
most common used converters
By alijutt in forum Video ConversionReplies: 0Last Post: 22nd Dec 2011, 20:35 -
Which Codecs or just not should you use with these 3 converters?
By NZBPirates in forum Video ConversionReplies: 4Last Post: 3rd Oct 2010, 14:23 -
Canopus ADVC110 or other converters
By pdx10 in forum Capturing and VCRReplies: 3Last Post: 13th May 2009, 13:35 -
Top 10 FLV converters
By OM2 in forum Newbie / General discussionsReplies: 10Last Post: 27th Dec 2008, 15:13 -
all in one converters
By JayLeo in forum Video ConversionReplies: 12Last Post: 3rd Sep 2007, 09:10
