Ok i just tried Audacity. I selected amplify and gave a minus 3db amplification. Is that what you did as well?
Results 31 to 35 of 35
More or less. I started with a stereo source, deleted one track, duplicated the remaining track (so there would be two identical tracks), then attenuated the second track by 3 dB so you could see the difference between the original and the attenuated track.Originally Posted by therock003
Ok i get it. Does overmodulation happens upon recording or during playback as well?
For example if i max out the volume on my headphones (from their volume controller) could that result for the sound to be delivered overmodulated? -
Overmodulation happens any time you drive a device with more power/volume than it can handle. If you feed a pair of headphones a clean signal but at a hither power than they can handle you will get distorted sound and eventually burn them out. Of course, all you have to do to fix the problem is turn down the volume (unless you've already burned the headphones out). Most amps will distort if you turn the volume up too loud. Again, just turning down the volume fixes the problem. But if you record something too loud you can't fix it. The distortion is permanent. You can attenuate the recording but the distortion will remain. Just record it right in the first place.
Hi All, I am stuck with a problem could anyone of you suggest how I can fix this.
I use PHX-USB Numark Headphone Jack. The 3.5mm stereo cable has a issue and it does not work. The normal 3.5mm stereo jack does not fit my headphones coz it has thread type. Look at the below link
http://www.jiscdigitalmedia.ac.uk/images/stereo-jacks2.jpg
It looks similar to the black one.
Can anyone suggest where do I get such type cables online ?
Tv with no headphone jack AND rca audio outputs
By gordes04 in forum DVB / IPTVReplies: 27Last Post: 23rd Jun 2013, 22:39 -
mono headphone mod to get stereo sound
By snafubaby in forum AudioReplies: 7Last Post: 5th Jun 2011, 20:54 -
Any ideas on why audio through headphone jack stutters on MacBook?
By ryangarfield in forum ComputerReplies: 2Last Post: 30th Mar 2010, 23:07 -
Headphone jack extenders?
By Nintendo Fan in forum Off topicReplies: 5Last Post: 5th Jan 2010, 12:25 -
Audio/Video jack - is this a headphone jack?
By OM2 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 26th May 2009, 17:10
