Can someone recommend a good Registry Cleaner for Window Vista Ultimate 64 bit. They seem hard to find. Some of them advertise Vista ready but won't work on the 64 bit.
I belong to the school that believes registry cleaners are a waste of time. -(Short answer)
If you think registry cleaners are a waste of time how do you prevent your registry from becoming bloated with:
1. Leftovers when uninstalling software
2. Malware caused by the badboys
3. Viruses caused by the badboys.
5. Trojans caused by the badboys.
6. etc
The registry is a database and will never grow smaller on its own.
After a good cleaning the registry should be compacted. This will give you back some harddrive space and speedup overall activity.(short answer) -
Never run into 2-5 on my system. Though people complain about Norton being a resource hog it has always served me well avoiding trash like that. As for #1 I generally don't install rubbish that leaves leftovers behind that aren't part of an upgrade. I also tend to check for stray entries after uninstall. Once you know your way around the registry it isn't too hard.Originally Posted by mystsFB-DIMM are the real cause of global warming
I used to edit my registry after uninstalling programs, but that can be a pain searching all the keys........
Regcleanr is an old app that seams to work well on my Vista Ultimate 64. I've only been using it for a few days though.........Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
use this to uninstall programs :/
http://www.download.com/Revo-Uninstaller/3000-2096_4-10687648.html?tag=mncolPhenII 955@3.74 - GA-790XTA-UD4 AM3 - 2x4 Corsair Vengeance@1600 - Radeon 5770 - Corsair 550VX - OCZ Agility 3 90GB WD BLACK 1TB - LiteOn 24x - Win 8 Preview - Logi G110+G500 -
i belong to this school: registry cleaners will not improve a computers performance.
but dont take my word for it;
http://lifehacker.com/5033518/debunking-common-windows-performance-tweaking-myths
http://www.edbott.com/weblog/?p=643
daily backups vs registry cleaners
By mysts in forum ComputerReplies: 6Last Post: 15th Jul 2009, 15:32 -
Vista Help
By kld712 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 4th Nov 2007, 15:34 -
What is the difference between Vista basic and Vista home premium?
By davidsama in forum ComputerReplies: 18Last Post: 27th Oct 2007, 13:01 -
Vista or Xp
By negy in forum Newbie / General discussionsReplies: 5Last Post: 28th Aug 2007, 21:15 -
Sharing TV - 1 Vista Media Center Server to Vista Media Center PC
By JBredensteiner in forum Media Center PC / MediaCentersReplies: 8Last Post: 14th Jul 2007, 02:33
