I have ripped a dvd using dvd decrypter and now have an ifo and vob file.
I then used AutoGK to convert the file to avi (xvid). I set the file size to be 700MB maximum. The converted video is 480 x 368 and is 699MB.
Then I used handbrake to convert the vob file. I also set the maximum size to 700 MB and used the avi xvid format. Yet this video is 704 x 572 and is only 493 MB.
Why is there such a difference between two programs?
As AutoGK has a known issue with making undersized files if an incorrect version of XviD is installed and ESS option is selected [packed bitstream], did you possibly get those stats backwards, what is length, are both movies complete? Maybe Handbrake has an issue with AutoGK's XviD. Use Portable AutoGK [internal XviD] to allow other apps to install their own required version [current XviD might have to be manually uninstalled first].
Intending to try the new version of Handbrake myself especially since it appears to accept any input, such as FLV etc. -
I have just tried the conversion again on both programs and have found that what I mentioned in the first post is correct. Both movies are complete.Originally Posted by citanool
The facts I stated in the first post are still the same, any ideas why is there such a difference between two programs?
Converting .VOB to .AVI
By reysaj in forum Newbie / General discussionsReplies: 11Last Post: 1st Dec 2010, 10:24 -
By reysaj in forum Video ConversionReplies: 1Last Post: 29th Nov 2010, 14:56 -
VOB IFO and VOB, clueless need expert help :)
By Skunk141 in forum Authoring (DVD)Replies: 5Last Post: 13th Dec 2007, 16:03 -
4 separate IFO files > one IFO to govern the full .VOB video
By Salva Veritate in forum EditingReplies: 4Last Post: 20th Aug 2007, 14:38 -
VOB/BUP/IFO to AVI???
By chronic777 in forum DVD RippingReplies: 6Last Post: 11th Aug 2007, 13:10
