Hi,
I've purchased a Toshiba LCD 32" LCD TV with the resolution of 1024x768. Actually I didn't know about the resolution until I bought it and that's why I haven't yet opened the box!
I can buy Vizio 32" with almost the same price but with 1366x768 resolution.
One thing that I'm not very sure about is that I don't know if a 1366x768 TV has a clearer image than a 1024x768 even if both of them are 720p.
Would you please help?
Sina
Results 1 to 9 of 9
It sounds like the Toshiba is a 4:3 standard screen, and the Vizio is a 16:9 wide screen.
"I will not be pushed, filed, stamped, indexed, briefed, debriefed, or numbered! My life is my own" - the Prisoner
(NO MAN IS JUST A NUMBER)
be seeing you ( RIP Patrick McGoohan ) -
Other things being equal, 1366x768 (finer square pixels) is a better match for 1280x720p than is 1024x768 (wide pixels). Most modern computer cards can drive 1366x768 1:1 for a much clearer computer or game image.Originally Posted by sina1358
Some 1024x768 plasma HDTVs may give a superior overall picture vs. a cheap 1366x768 LCD but for 32" LCD, 1024x768 indicates older technology.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Hi,Originally Posted by edDV
Thanks for the answer.
But I cannot understand the difference between the resolution which can be 1366x768 or 1024x768 and 1280x720p? -
Neither one is 720p. They are what they are.Originally Posted by sina1358
You didn't understand his answer? The 1366x768 is a square pixel screen and the 1024x768 one is a wide (non-square) pixel screen. Both will take a 720p (or 1080i/p or 480i/p or any other source) input and up or down scale it to the native resolution of your TV set. You have a fixed-pixel display - it only displays its one resolution. Any input resolutions which are different than yours (meaning all of them) will be converted to yours.Originally Posted by sina1358
As for which is better - in general the 1366x768 one will be but as edDV said, a good 1024x768 TV set may beat a lousy 1366x768 TV set. Me, I'd advise not getting either, but get the best 1080p set you can afford. They're coming down in price very quickly. And then sit real close if it's a 32 incher.
Hi,Originally Posted by manono
Thank you for the post. I opened the TV, The picture quality is great but most of the channels don't fit the TV and there are two black borders on left and right hand side of them. For example David Letterman show on CBS was full screen but the next program was not! I just want to know if these two black borders also exist on 1366x768 resolution TVs or exist just on 1024x768 32"?
Thanks -
Many programs are 4:3 material (usually standard definition) broadcast in a 16:9 frame by (upscaling, if SD, and) adding pillarboxes to the sides.
How is the quality of small sized 720p BDRips and BRRips on LCD TV's?
By llllllllll in forum Newbie / General discussionsReplies: 7Last Post: 9th Mar 2011, 09:32 -
720p turns out as 480p on my HD lcd on PS3??
By bagmand22 in forum SubtitleReplies: 17Last Post: 13th Sep 2009, 09:51 -
how to watch 720p movies on new lcd
By goofymickey in forum Video ConversionReplies: 3Last Post: 11th Sep 2008, 12:36 -
Playing 1080p video at 1366x768-does it downconvert to 720p?
By bigshotceo in forum DVB / IPTVReplies: 15Last Post: 28th Feb 2008, 15:54 -
Resolutions...why call it 720p when the res. is 1366x768 ?
By snadge in forum DVB / IPTVReplies: 4Last Post: 29th Aug 2007, 18:30
