Hello all, I'm using a BlackMagic Intensity (not pro) capture card and when I boot up Premiere it's not even listed under the selectable devices. I've updated the drivers for the card and the card is listed in the device manager. Any ideas?
Vista 64-bit
Intel Core i7 920
6 GB Ram
8800gt
Just cap with BlackMagic's included software then import the MJPEG file.Originally Posted by ercdill
The card can also produce uncompressed video but to cap that you need a 2-4 disk RAID zero.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Can you import from Adobe After Affects to Adobe Premiere Pro?
By Devilsadvocate in forum EditingReplies: 9Last Post: 29th Feb 2012, 21:43 -
Adobe Premiere Pro CS3 & Vegas Pro help
By KS89 in forum EditingReplies: 1Last Post: 8th Sep 2009, 22:52 -
SxS Pro card file MXF to DVD using Adobe Premiere Pro CS3
By Fary4u in forum Video ConversionReplies: 8Last Post: 20th Jul 2009, 09:00 -
Should I get Adobe Premiere Pro CS4? - Upgrade from Pro 1.5
By vid83 in forum Newbie / General discussionsReplies: 0Last Post: 22nd Feb 2009, 17:10 -
Adobe premiere pro 2?????
By Reggie6966 in forum EditingReplies: 10Last Post: 19th May 2007, 22:18
