Hello,
After a successfull erase/format operation of a dvdrw, a window pops up with the only possible choice being cancel. The O.K. option is greyed out. After clicking cancel, a warning pop up appears "Are you sure you want to abort the operation? Aborting may damage your CD permanently". There is a yes/no choice. Either choice results in a frozen screen. The only way to exit the program is to cnt/alt/del to the task manager.![]()
Any ideas?------------Thank you
The only idea I can offer is dump Infrarecorder and use Imgburn instead.
Buy My Books -
One of these guides should help.
http://forum.imgburn.com/index.php?showforum=4"Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books -
gadgetguy,
Thanks very much for the link, I've got some reading to do.
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 11:17 -
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 13:24 -
InfraRecorder Help! Or please suggest free 1 to 1 dvd copying softwares..
By siratfus in forum Authoring (DVD)Replies: 4Last Post: 7th Dec 2009, 01:10 -
Mod16 question and DAR question...
By alcOre in forum Newbie / General discussionsReplies: 5Last Post: 31st Oct 2008, 15:18 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 22:43
