I know someone with a DivX player but no USB port on it and they asked me to put a AVI onto disk for them.
If I put the file onto DVD-R for them it would be a waste of a disk because it would hardly use up space on it.
Is it possible to burn it to DVD-RW so that I can then format it afterwards and re use it for the same purpose without loss of quality for the second time, third time etc?
thanks
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Yes, of course it is possible. But have you considered putting the avi file on a CD instead of a DVD? Divx /xvid avi files are placed as data on the disc, so a CD would work fine if the video is less than 700mb.
Never really thought about using a CD, might consider it cheers.
So about re-using the disk, will there be loss of quality after the first time? -
No, there's no loss of quality, but my experience is that re-writable DVDs don't last anywhere near as long as they are claimed to. I've seen some seem to fail after only one burn. That's a worst case scenario for sure and it doesn't happen a lot, but it has happened.
I might just try it and find out, I fear skipping/freezing after re-using it
cheers -
Nah!!
I have some dvd+rw's i have reused a good 100 times so far for watching Xvid's, dvd video, ect. on and they still work fine.
Of course if you don't take care of them like any dvdr, like scratches, they will start acting up.
And then there is the issue that "some" players might just not like RW media.
Originally Posted by Tbag
Usually your burning program will just say everything on the disc will be written over or erased and you just hit go.
Reformatting any disc over and over can cause them to fail prematurely.
Originally Posted by Tbag -
Im gonna use Sony +RW, I think I might have some TDK +/-RW about somewhere and they will be taken care of in a jewel case.
I guess i'll find out if there player reads it ok.
thanks
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 09:11 -
burning divx files as data to play on dvd player
By penguyen in forum Authoring (DVD)Replies: 4Last Post: 30th Jul 2011, 10:54 -
Burning AVI file to DVD-RW to play on a Divx DVD player
By Jay8284 in forum Authoring (DVD)Replies: 4Last Post: 5th Jan 2008, 14:03 -
Best program for burning .avi to DVD for DVD Player, retaining quality?
By Calcyon in forum Authoring (DVD)Replies: 1Last Post: 11th Dec 2007, 00:53 -
Standalone Divx DVD player/burning/conversion quandry
By wellsyuk in forum Newbie / General discussionsReplies: 21Last Post: 3rd Jun 2007, 06:48
