Hi, I'm hoping somebody can help me out here, I've lost sound on both my TV apps „Tvtime“ and „XdTV“ and microphone also fails. Running Ubuntu „Gutsy“....nForce3 250Gb AC'97 Audio Controller....using Nvidia CK8S ALSA capture device and tuner is SAA7134/SAA7135HL Video Broadcast Decoder. I connect straight from tv card into sound card with audio lead and the sound from output of tv card is o.k., the sound card just isn't processing it through although everything played internally works. I have two identical „Gutsy“ installations (one I use just as test, which is fully-functional including all sound), so I use exactly identical mixer settings and still no sound....the problem lies elsewhere. I've tried a multitude of other settings, I've tried a reinstall (Synaptec) of both ALSA and OSS, nothing works, I'm way out of my depth here and would really appreciate any help, am still more or less new to Ubuntu.
To those with a similar sound scenario, I eventually found a combination of settings which solved microphone and other problems.....
In volume control/ edit/preferences „Channel Mode“ activated and set to 2 channels.
Settings under System/Preferences/Sound also changed, see screenshot...
http://img408.imageshack.us/img408/7744/soundpreferencesso6.png
Sound in Ubuntu, in my opinion, is too much hit 'n' miss, many other people have had similar problems, just check out the forums!
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
Problem Using ProjectX: the sound's output is "corrupted"
By devilcoelhodog in forum Newbie / General discussionsReplies: 0Last Post: 12th Nov 2010, 16:22 -
"there is a problem with your sound hardware." error message
By arconreef in forum AudioReplies: 1Last Post: 8th Nov 2010, 14:58 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 01:27 -
Quality problem "caused" during "deinterlacing" ?
By Hombre_86 in forum DVD RippingReplies: 26Last Post: 25th May 2010, 21:28
