Trying to convert an VOB file to an MPG so I can watch it using quicktime on my Mac. Most of the time it works fine, however for some files the audio is about 5-10 seconds behind the video. The settings that work most of the time are the defaults:
Codec AAC
Bit rate 96
Sampling 48000
Channels Stereo
Mode CBR
If I try other Codec the files are unplayable. Any suggestions on getting the timing correct?
Did you check the duration of the source file with the duration of the output audio and output video? I'm asking, because most often with sync issues, it is the audio that is fine and it is the video that drifts. If that is indeed the case, then your audio details are mostly irrelevant.
audio and video not in synch by a second or two problem
By sabathiel in forum Capturing and VCRReplies: 0Last Post: 14th Oct 2011, 22:45 -
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 16:12 -
Audio synch problem after IVTC
By avengerevenge in forum AudioReplies: 1Last Post: 15th Feb 2010, 12:34 -
Video/Audio synch problem
By tangomango in forum Newbie / General discussionsReplies: 2Last Post: 8th Sep 2008, 13:19 -
Audio Synch problem using AviSynch
By spycraft in forum Newbie / General discussionsReplies: 21Last Post: 4th Jul 2007, 05:04
