Results 1 to 19 of 19
    Dec 2008
    Saudi Arabia
    I have a chinese 3.5 HDD recorder. The recorded videos are playable on my PC, but when I open these videos with VirtualDub i got squares and all sort of noise on them as seen in this picture
    Please help
    regards
    Please give us MORE information,
    What video and audio codec? Identify using mediainfo.
    What container? wmv,asf,avi,mp4,etc
    And try open them in avidemux.
    Dec 2008
    Saudi Arabia
    Sorry
    This is the mediainfo text
    thanks
    General
    Complete name : I:\MOVIE\AVI00020.AVI
    Format : AVI
    File size : 1.98 GiB
    Duration : 42mn 54s
    Overall bit rate : 6 603 Kbps
    Video
    Format : MPEG-4 Visual
    Format profile : Main@L3
    Format settings, BVOP : Yes
    Format settings, QPel : No
    Format settings, GMC : No warppoints
    Format settings, Matrix : Default
    Codec ID : XVID
    Codec ID/Hint : XviD
    Duration : 42mn 54s
    Bit rate : 6 465 Kbps
    Width : 720 pixels
    Height : 576 pixels
    Display aspect ratio : 4/3
    Frame rate : 25.000 fps
    Standard : PAL
    Resolution : 24 bits
    Colorimetry : 4:2:0
    Scan type : Interlaced
    Scan order : Top Field First
    Bits/(Pixel*Frame) : 0.624
    Stream size : 1.94 GiB (98%)
    Writing library : XviD 1.0.0 RC2 (Jambo) (UTC 2004-02-01)
    Audio
    Format : MPEG Audio
    Format version : Version 1
    Format profile : Layer 2
    Codec ID : 50
    Codec ID/Hint : MP1
    Duration : 42mn 54s
    Bit rate mode : Constant
    Bit rate : 128 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Resolution : 16 bits
    Stream size : 39.3 MiB (2%)
    Alignment : Split accross interleaves
    Interleave, duration : 40 ms (1.00 video frame)
    Interleave, preload duration : 150 ms
    And did you try open it in avidemux? Same problem?
  5. Update Xvid codec. Try a different MPEG4 decoder -- Divx codec, ffdshow...
    Dec 2008
    Saudi Arabia
    I opened it with avidemux and is working fine. but it asked me to rebuild index eveytime I open a file. I also notices that it's not as powerfull is VIrtualDub, as it seems to be halting and crashing. is there a way I can use the file with VirtualDub.
    regards
    Dec 2008
    Saudi Arabia
    I actually have both of these installed, is it possible to have these conflicting and causing this problem?
  8. I'm a MEGA Super Moderator Baldrick's Avatar
    Disable xvid decoding in ffdshow(under video decoder configuration->codecs and set xvid to disabled) and then reinstall latest xvid codec.
    Dec 2008
    Saudi Arabia
    I did this but it didn't solve the issue. I unistalled xvid and the file did open with VirtualDub. My favorite codec is xvid, does this mean I can not use xvid?
    I appretiate your help.
  10. I'm a MEGA Super Moderator Baldrick's Avatar
    Using latest virtualdub 1.8.6 ?
    Dec 2008
    Saudi Arabia
    I just downloaded virtualdub 1.8.6 and re-installed latest Xvid and the problem came back.
    what to do?
  12. Looks like your HDD recorder's MPEG4.2 encoder is incompatible with Xvid's decoder. Set ffdshow's MPEG4.2 decoder at a higher priority than Xvid's.
    Dec 2008
    Saudi Arabia
    how can this be done?
    this is a video sample of my problem
    http://www.youtube.com/watch?v=OUvJINs8ymc
    Dec 2008
    Saudi Arabia
    Update!
    I can open the videos now with no problem,
    I had to go to ffdshow/VFW configuration/ decoder and set xvid to libavcodec, it worked fine.
    when I re-installed xvid because I need it to compress some files, the problem came back.
    any advice?
    regards
  15. Install Xvid before installing ffdshow. Or use a filter manager to de-prioritize xvid. Radlight Filter Manager, Filmerit, etc.
    Dec 2008
    Saudi Arabia
    I have installed both manages and tried to reduce the merit of the Xvid DirectShow filter,
    The issue still exist.
  17. Originally Posted by Equarter
    Did you reboot? You have to reboot before the new merit becomes effective.
  18. Member
    Dec 2008
    Saudi Arabia
    I tried the reboot, but it didn't work
    I used filerit, DirectShow Filters, Xvid MPEG-4 Video Decoder and set the merit to 00200000 Don't Use.
    am I doing it right?
    thanks
  19. Sorry, I forgot you are having problems in VirtualDub. That uses VFW filters, not DirectShow filters. So changing the priority in DirectShow (via filter managers) won't make any difference. The only way I know to set the order in VFW is by installation order -- the last one installed is the one that's used. I would uninstall both Xvid and ffdshow. Then install Xvid and install ffdshow. Make sure you enable ffdshow's xvid decoder via its VFW Configuration option.
