Hi M8s
I convert an avi file to dvd, the files are then saved in "svcd2dvd_output" folder, i then have to delete these files before i convert another avi file or i will then have 2 lots of converted files in the folder, i seem to recall in a previous version the proggy prompted you saying "folder not empty" where can i change this setting? any help appreceated
geb
Results 1 to 10 of 10
It should always prompt you. What version are you running?
build?
try the latest build.
Basically it looks for files in the VIDEO_TS folder under svcd2dvd_output... are there definatly files in there?SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
yes when i convert another avi file there are two lots of files in the folder.
Hi M8s
Still having problems with svcd2dvd_output folder, using default settings in options, the proggy won't use the output folder it creates a new output folder where i store my "Avi" files, then when i convert another "Avi" it creates another folder, so i end up with lots of output folders, -
cool!
batch dvd ripping - output folder to input folder?
By mkv2avi in forum DVD RippingReplies: 5Last Post: 17th Apr 2012, 16:23 -
Wgat would be the proper folder structure to add movie cover to a folder
By VoodooEvil in forum Newbie / General discussionsReplies: 1Last Post: 9th Feb 2012, 19:09 -
Pioneer Players wont play SVCD2DVD Creations...fix?
By alangriffin in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 2nd Jul 2008, 09:06 -
VOB files - Video _ TS folder wont record dts codec on toast 7
By BattyRoy in forum MacReplies: 8Last Post: 10th Apr 2008, 00:30 -
SVCD2DVD 2.5.2725 Wont create dvd
By Stuart-ASI in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 21st Jun 2007, 18:54
