i updated my computer to service pack 3 and for some reason my windows media player will not work. i tried to update it on Microsoft but its not working. i think the problem is in the codec but im not sure i went online and downloaded the latest version but its still not working. any suggestions?
Results 1 to 9 of 9
We don't stop playing because we grow old; we grow old because we stop playing.” (George Bernard Shaw, 1856-1950)
Does it play WMV media files? If not, major problem as those are built in.
MPEG-2 and others, you may need to add the codecs. You can check most files with Gspot to see what codecs are needed and if you have them. Probably need MediaInfo for checking WMV files.
Or just try VLC Media Player. It plays most anything and doesn't need any added codecs.
it does not play any kind of file its wierd
We don't stop playing because we grow old; we grow old because we stop playing.” (George Bernard Shaw, 1856-1950) -
yeah i dowloaded wmp 11 also did not work. but my teacher told me to download k lite codec pack and it fixed it. the program installs codecs for any type of media players
K-lite also has a bad habit of damaging existing codecs and causing many more problems than it solves. And it rarely uninstalls cleanly. I consider it bad advice to recommend K-lite or most any codec pack to anyone.
Good luck.
The K-Lite Codec Tweak Tool, on the other hand, is useful for spotting broken filters, etc. If you're ever in a bad way with DirectShow one of the things you can do is use Zoomplayer to unregister ALL filters and then use the built-in option to register only the default system filters; from there, you can re-install CoreAVC, ffdshow, Haali, etc.
i dont know if its bad or good but right now im just glad it work again if ill have problems ill remember this post
I can't even get it to install. MS is really getting flaky with their new updates. I get permission denied messages that require registry hacks.
How to make Media Player Classic's window size stay the same when playing m
By DigitalAbstracts in forum Newbie / General discussionsReplies: 5Last Post: 28th Jun 2016, 20:35 -
Need help for Window/VLC Media Player
By Neil_2004 in forum Video Streaming DownloadingReplies: 2Last Post: 27th Feb 2012, 20:05 -
How to send video of window media player thru mail
By rajshri in forum Newbie / General discussionsReplies: 1Last Post: 2nd Jun 2009, 13:46 -
Why these movies did NOT work fine in my (WD TV HD Media Player)
By Sanshero in forum Video ConversionReplies: 8Last Post: 28th Mar 2009, 19:55 -
Window Media Player and TV
By BobV in forum Newbie / General discussionsReplies: 1Last Post: 11th Feb 2008, 17:34
