Hi all
Good thing I read the forum so I dont have to ask why a x264 compression resized to half the original framesize had the same filesize as compressed at original framesize with the same bitrate
nevertheless I would like to have some opinions on finding a balance between quality and filesize ( and compression speed) knowing that most of it can be very subjective .
I made a batch to convert hundreds of short (1 -1.5 minutes) clips regularly to deliver online to the subjects in the clips. I know that nothing beats the original (also debatable ) but its just impractical .
currently this is the process:
Source NTSC DV (fast moving/sport)
avisynth :
ConvertToYV12()
Yadif()
depend on the shoot some cropping (top and bottom)
LanczosResize(640,480) or vertically addapted to the cropping
Trim() based on external data
a subtitle()
a logo with scriptclip()
x264 parameters: --bitrate 1300 --stats ".stats" --keyint 300 --min-keyint 30 --ref 2 --mixed-refs --bframes 3 --b-pyramid --bime --weightb --direct auto --filter -1:-1 --subme 6 --partitions all --8x8dct --vbv-maxrate 2000 --no-fast-pskip --scenecut 30 --threads auto --progress --no-psnr --no-ssim .
I will admit I dont see the difference that well that many of you see when changing many of the parameters in a subtle way. Trying to understand all the settings as best as I can but takes time.
In other post its mentioned that bitrate of 1024 woudl be good for example and I tried it, somethimes I see difference in result but cant put my finger on it as seems to affect like static text , but comparing a screenshot of both I dont see a major difference. ( I am learning !)
Maybe one would say , well if you dont see a much difference why bother, but I do as I feel there will be catch later .
no doubt it can be tweaked to find a better balance between filesize, compression times and viewingquality
Any advice higly appreciated
tnx
G
Results 1 to 28 of 28
Post a short clip of your original DV file somewhere.
A fast noise reduction filter which works well with DV material is Fluxsmooth. Unzip and place in your Avisynth plugins folder. This will let you get away with lower bitrate video.
http://kvcd.net/sansgrip/avisynth/FluxSmooth-1.1a.zip
You'd put it in this order
Yadif()
FluxsmoothST()
BicubicResize(640,480) -
10-15 seconds with some movement in the scenes.
Also, Yadif() before you do the conversion to YV12 will result in cleaner colors in the deinterlaced video. -
Doggyjumper, are you sending this to customers who would typically use Quicktime to view the resulting files? Here's what MeGUI uses for Quicktime compatibility ("Quicktime for Windows Unrestricted 2-Pass"):
--bitrate 1000 --stats ".stats" --ref 5 --bframes 1 --b-adapt 2 --direct auto --subme 7 --trellis 2 --partitions p8x8,b8x8,i4x4 --me umh --threads auto --thread-input --progress --no-psnr --no-ssim
x264 parameters: --bitrate 1300 --stats ".stats" --keyint 300 --min-keyint 30 --ref 2 --bframes 1 --direct auto --filter -1:-1 --subme 6 --partitions p8x8,b8x8,i4x4 --vbv-maxrate 2000 --no-fast-pskip --scenecut 30 --threads auto --progress --no-psnr --no-ssim
If you don't feel restricted to Quicktime by your target market, then go ahead and push x264 to the limits of efficiency
Also, some bitrate suggestions: Try encoding a few clips with your preferred Avisynth profile and x264 options with one-pass CRF at quality 18 to quality 24 or so. If, at (for instance) CRF 22 a high-motion, high-contrast source isn't easily distinguishable to you from the original, try at CRF 23 and so on until you can spot the difference. The bitrate of those final few smallest indistinguishable clips will be a good starting point for similar sources and if you're focused on a relatively consistent filesize you can adjust it upward or downward as needed. Good luck! -
trying CRF encoding is a good idea !
Quicktime is supposed to supported only 1 b-frame but I made differents tests using 3 b-frames and QT had no problem handling the video ! it would still required no b-pyramid and weighted b-prediction ,adapt DCT and so on ... but it could help to lower the bitrate! -
DOnt ask why , but for some reason I dont like QT (but maybe I shoudl get used to it)
Many of the people that like their clip have no clue what player they have on their computer.
I did notice the clips where not playing properly in QT so I adviced them GOMplayer (no fuss for them to install )
Online viewing is no problem at all
I chose x264 becasue it looks so much better then wmv etc compared to filesize
Guess I must have played a bit wrongly with the settings etc
I do admit that at times even trying out filters I have a hard time figuring the differences it makes ( I do see them but cant realy pinpoint them in how what to change , does that make sence ? .
They look good , people are happy , filesize is aceptable but I feel it can be better ( even if it' source is DV)
Thanks for the suggestions all , need to play again(and try to fully understand the differences )
G -
Lots of info
we have 2 main parts if I am correct
The avisynth part with filters etc to improve the footage
and the compression , keep as much of the original/improvemnt as possible
right ?
I didnt post the links to some footage here, hope you understand (but there are some available: pm)
btw, have used gui's but how does one tell to do a 2-pass in a ordenary batch script
G -
Yes,
1) preprocessing/filtering
2) encoder settings
Now you haven't posted a sample clip so I'm going to make some broad generalizations that may or may not apply to your particular source.
If you are using lower bitrate range ~1000-1300kbps for 640x480 sized frame, you might want to turn off psy-rd, or at least lower the value (default in the main x264 branch if you are using a modern build is 1.0:0 for psy-rd and psy-trellis) because it tends to cause outlining artifacting in smoother images at low bitrates.
--psy-rd 0.0:0
This might be what you were referring to when you said "it as seems to affect like static text " - you can see this when you use low bitrates and you have words/letters in the frame, you often see "haloing".
Also in this bitrate range, you might want to increase alpha & beta values to 0:0 or even 1:1 ; not only does doing these 2 things lower the bitrate required (in effect there is less "noisy detail"), but the image is cleaner & smoother - so along with a denoiser/smoother that Soopa suggested, you should get better results
If you were going for a high detail, grainy sharp picture - like many Hollywood films - this strategy wouldn't work. This is where the psy effects, and using higher bitrate shine.
It would be a good idea to test settings on a small representative test sample, then vary the settings & try again until you find a good combination of speed/quality that meets your goals. -
The deinterlacing method will also make a big difference, especially when it comes to the visual artifacts (aka the jaggies). Have a look at the various deinterlacers and the results. Better quality = slower processing time
stockholma_0-520_q3_yadif_mvbobmod_tgmca4_tdtmm.avi
BTW, I didn't create the above clip, credits to the person (unknown) who did.
The TempGaussMC method (obviously the best visual quality) transcodes at 2fps, compared to Yadif, which screams along at 38fps. -
^ Nice comparison Soopa!
I can't believe TempGaussMC is so much better than mvbob in that sample, I always thought they were close
I'd love to see that test re-done with Nvidia hardware deinterlacer that Neuron2 is working on for DGAVCdecNV and DGVC1decNV a(nd hopefully DGMPEGdecNV) -
Originally Posted by poisondeathray
working from a bat file/script
G -
What revision of x264 ? Around r900+ starting having psy optimizations
you can change strength e.g.
--psy-rd 0.5:0
or
--psy-rd 0:0 -
thought I had the latest as I just have reinstalled everything , guess I didnt
just got rev1046 , its going
tnx
G -
dont say that , a barely get 9 as it is
told you i dont have the latest -
This is an older comparison of denoisers, what you expect for compression vs. speed, from doom9. It was done before dual cores & quad cores, so I don't know how valid the results are now...
http://forum.doom9.org/showthread.php?t=51181
Code:* = Added on first edit ** = Added on second edit *** = Last added Denoiser Time Size Noisy clip None 5:33 (100%) 64,0 (100%) *Unfilter(-5,-5) 5:33 (100%) 56.0 (88%) *Undot() ´ 5:35 (101%) 61.4 (96%) temporalsoften(2,3,3,2,6) 5:47 (104%) 62,5 (98%) Mergechroma(blur(1.3)) 5:48 (105%) 61,4 (96%) **DNR2() 5:57 (108%) 62.0 (97%) *TemporalCleaner() 5:57 (108%) 62.0 (97%) temporalsoften(3,5,5,2,10) 5:59 (108%) 59,8 (93%) **STMedianFilter(8,15,4,7) 6:04 (109%) 60.3 (94%) temporalsoften(4,8,8,2,10) 6:04 (109%) 58,0 (91%) *Deen() 6:08 (111%) 53.3 (83%) fluxsmooth() 6:11 (111%) 57,4 (90%) convolution3d("moviehq") 6:14 (112%) 62,2 (97%) convolution3d("movielq") 6:14 (112%) 59,7 (93%) **Peachsmoother() 6:28 (117%) 53.7 (84%) SpaceDust() 6:46 (122%) 54,0 (84%) ****convolution3d("vhsbq") 7:05 (128%) 57.6 (90%) **SmoothHiQ(7,20,25,230,5) 16:54 (305%) 50.3 (79%) FaeryDust() 26:17 (474%) 55,6 (87%) PixieDust() 26:36 (479%) 48,7 (76%) GoldDust() 26:49 (483%) 40,4 (63%) Clean clip None 3:20 (100%) 26,3 (100%) *Undot() 3:21 (101%) 25.8 (98%) *Unfilter(-5,-5) 3:22 (101%) 23.5 (89%) Mergechroma(blur(1.3)) 3:30 (105%) 25,9 (98%) **DNR2() 3:31 (106%) 26.7 (102%) (!?) temporalsoften(2,3,3,2,6) 3:34 (107%) 25,5 (97%) temporalsoften(3,5,5,2,10) 3:42 (111%) 25,1 (95%) **STMedianFilter(8,15,4,7) 3:43 (112%) 26.2 (100%) *TemporalCleaner() 3:45 (113%) 25.9 (98%) temporalsoften(4,8,8,2,10) 3:47 (114%) 24,9 (95%) fluxsmooth() 3:50 (115%) 24,2 (92%) *Deen() 3:56 (118%) 22.4 (85%) convolution3d(movielq) 3:58 (119%) 25,0 (95%) convolution3d(moviehq) 3:59 (120%) 25,6 (97%) **Peachsmoother() 4:03 (122%) 24.3 (92%) SpaceDust() 4:07 (124%) 22,2 (84%) ***convolution3d("vhsbq") 4:23 (132%) 25.1 (95%) FaeryDust() 12:14 (367%) 23,9 (91%) GoldDust() 12:45 (383%) 20,5 (78%) PixieDust() 12:48 (384%) 22,3 (85%) **SmoothHiQ(7,20,25,230,5) 14:10 (425%) 20.6 (78%)
Good idea.
doggyjumper - change your Yadif command to
Yadif(mode=1,order=0) -
If you're distributing the files to people who are not too technically inclined, and thus likely to use Quicktime
been reminded of why I dont like QT
Been playing with the suggestions you guys gave me so far (still hard to see the subtleties , how do you guys do it ?) and well... playback in QT litterally S***. takes long time to load , jerky ( less then before ) and the colors ..
VLC, GOM even Window Mplayer (with FFdshow) are so much more satisfying to watch with.
Be it people are informed of the player to use , it seems better to not focus on playback in QT if they have it installed . Even better make it as bad as possible there but as good as possible in the others to force them to complain if they didnt read the information given so they do use the 'better' ones .
Yes most of them are completely computer illiterate , but its still easyer to explain them how to save a file follow a link and download a descend player . irronique but true . Last thing one wants is to explain how to change settings
so whe have now nr 3 in the list
2) encoder settings
3) player
G -
After trying out all the valueable suggestions which meant I had to included the latest build of x264 I now get "no ratecontrol methos specified" when I try my old settings ( first post) to compare
any ideas please -
It looks like you are doing a 1 pass ABR, not 2 pass ?
You need to add --pass 1 and --pass 2 for your passes, respectively
If you were going to do 1 pass, I would use CRF mode instead of ABR
Why not use a GUI to simplify & speed up things? e.g. MeGUI you can add/modify custom command lines and it has presets (you also create presets). There are other GUI's that work well too e.g. xvid4psp, ripbot264 -
thanks
as mentioned before I am working from a batfile with some vbs for clipdetail processing (involves external trim details and stopwatch info) ( converting lots of small clips on a regular basis) -
Doggyjumper, MEGUI uses slightly different syntax at the beginning of the command line than a batch file calling X264 directly would, I believe. Post your batch script as it looks now and I'm sure someone can help you sort it out. You might also try encoding with one of the MeGUI presets and using that through MeGUI (e.g., open your Avisynth script in MeGUI, set encoding options, queue it up, and start encoding).
Is what I did ( Megui)
For example Megui will show
program --crf 18 --ref 3 --mixed-refs --bframes 16 --b-pyramid --weightb --deblock -1:-1 --trellis 1 --partitions p8x8,b8x8,i4x4,i8x8 --8x8dct --threads auto --thread-input --progress --no-psnr --no-ssim --output "output" "input"
so I copy :
--crf 23.5 --ref 3 --mixed-refs --bframes 16 --b-pyramid --weightb --deblock -1:-1 --trellis 1 --partitions p8x8,b8x8,i4x4,i8x8 --8x8dct --threads auto --thread-input --progress --no-psnr --no-ssim
resulting in the error
this works in the same script : --bitrate 1000 --stats ".stats" --keyint 300 --min-keyint 30 --ref 2 --mixed-refs --bframes 3 --b-pyramid --weightb --direct auto --filter -1:-1 --subme 6 --partitions all --8x8dct --vbv-maxrate 2000 --no-fast-pskip --scenecut 30 --threads auto --progress --psy-rd 0.5:0 --no-psnr --no-ssim
The code does specify the x264 location andof course the out and source are specified also
G -
What version of x264.exe?
Are you using .avs as input for your custom batch file? (i.e. is this done through avisynth and using filters)?
I don't think you can just copy the commandline from megui's commandline box because it omits some syntax, have a look at a sample encode's log file for the proper (full) command line -
that did the trick : --sar 1:1 was missing
thanks a bunch
I never stick to : if it aint broke , dont fix it
Edit : weird , got the error again when I switched between one and the other command line settings, went back again , no errors ?
re: A little 'balance', please.
By StewieTeabag in forum RestorationReplies: 49Last Post: 25th Nov 2010, 12:56 -
Bitrate vs Size Calculator for x264 for ripping DVD to x264 + AC3
By Bonie81 in forum DVD RippingReplies: 7Last Post: 5th Jul 2010, 18:24 -
Color problem with x264 output + other x264 questions
By serexl in forum Newbie / General discussionsReplies: 3Last Post: 15th Mar 2010, 18:31 -
x264: -1920, -ESiR, -SEPTiC, -CiNEFiLE.... What are these x264 extentions?
By NWNewell in forum Newbie / General discussionsReplies: 7Last Post: 18th May 2009, 17:10 -
Need to balance audio
By grayprint in forum RestorationReplies: 2Last Post: 25th Feb 2009, 13:51
