Results 1 to 22 of 22
    Dec 2008
    Denmark
    Hi there.
    I'm totally newbie at this whole movie editing thing.
    The case is, i want to edit in some snowboard recordings i have made, but i want to be using the best program from the start, so i don't have to learn another program after a while.
    I've heard Sony Vegas Pro is good, but some say Adobe Premiere Pro + Adobe After Effects is really pro.
    What do all you hardcore editors use?
    The prize doesn't matter.
    Cheers
    The only powder that gets me high, is the powder from the sky
    Jan 2007
    Republic of Texas
    You're about the 8000th person to ask the unanswerable question. "Best" is relative. It depends on your source format, your targeted final output, your work style (meaning, which work area interface best suits you), your budget, your computer system capabilities, etc.
    The products you mentioned are very good. "Hardcore editors" could mean a lot of things. Are you talking about Hollywood-level, broadcast television compliant, home DVD distribution, YouTube upload...what?
    Dec 2008
    Denmark
    Yeah, you are right.
    Final output is just a nice looking video, maybe for a DVD.
    Nothing totally hollywood level thing, just home editing.
    In future, i dream about making something like this:
    http://vimeo.com/1447460?pg=embed&sec=1447460
    But for now, i just need to cut together and add some music and simple effects.
  4. Member tmw's Avatar
    Jan 2004
    What is your source material?
    Dec 2008
    Denmark
    Well it is recorded with a Mini-DV camcorder.
  6. Member Seeker47's Avatar
    Jul 2005
    All good points. I have the trial version of VideoRedo at the moment. But it seems like it is intended for use only on the .MPG format. My use of it has been very limited so far -- mainly to repair some bad .MPG files -- but it did reject a couple other video file formats I tried to load. So, I'm thinking the only option there might be to convert such files to MPG first, which may well have some drawbacks. It sounds reasonable to this video editing beginner that there would not be any one program that can edit any or most video formats, and do so well.
    One thing that I would find very useful is if there was some kind of at-a-glance chart listing all the prevalent video formats, and which of the editing programs commonly discussed here is appropriate for editing each type of video. Ditto for demux / remux, and video repair. Then we'd have a concise roadmap of our available options. (We can then sort out the simpler from the intermediate or advanced level programs, and price levels, on our own.)
    [P.S.: VLC can repair some .AVI files that have bad indexes. Just found that out.]
    Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com
    Dec 2008
    Canada
    I use Windows Movie Maker and like it a lot.
    Aug 2002
    South Florida
    Video Studio 12 is probably what you need. Leave the hi-powered stuff to the Pros. It produces very nice results. I use it and VideoRedo for the edits.
  9. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    It might take you a couple or more years to become reasonably proficient with Premiere Pro CS3 and After Effects. Maybe 5 years to be job competitive.
    http://www.kiva.org/about
  10. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    If you just want to do home videos then I second VideoStudio as a good starting point. It handles most formats and produces good results.
    If you are starting out with an eye to going somewhere with it you might consider Vegas Movie Studio or Premiere Elements. Both are cut down versions of their big brothers. You can progress up to Vegas Pro or Premiere Pro down the track without having the same learning curve.
    After Effects is a higher end effects and motion graphics package, and at this stage probably more of a distraction than something you really need.
    Read my blog here.
  11. Member PuzZLeR's Avatar
    Oct 2006
    Toronto Canada
    Let me also recommend VideoStudio.
    -Very easy to learn and start using - even for full productions on the first day.
    -Very inexpensive for a well rounded package - only about $100 (you can even try it for free).
    -Has a great forum for any support.
    -Can work with many different formats (input and output) - even mixed within your production.
    -Can pretty much do it all, even much of what that sample video you posted demonstrates.
    -It works.
    This is where I got my start in this hobby. VS is certainly not meant to be "the best", but it's the "jack of all trades, master of none" edit software and IMO perfect for the newbie.
    If your hobby progresses, then you can move on, or even invest in, more expensive or more advanced stuff, but at least VS should give you a good start, and establish a proper initial learning curve.
    I hate VHS. I always did.
  12. Member zoobie's Avatar
    Feb 2005
    Florida
    agreed...try all the free demos first
    I saw VS 11 on ebay.uk for 30 quid...even cheaper in the USA @ U$36
    you can freely update to 11.5, the latest
  13. OK, I'll be the only one to recommend AvidFree (can still be found on the net even though they don't offer it anymore on avid.com) It's a cut down version of Avid Xpress Pro/Newscutter.
    If you're going the TV route, it's almost a must have. Then again you'll also want to think about Edius too
    Grassvalley is starting to push hard
    Forgot to mention, both have VERY steep learning curves
    Originally Posted by jagabo
    Dec 2008
    Denmark
    Thanks you all for your advice.
    I will start with VideoStudio, sounds like it's pretty easy Thanks!
  15. Video Restorer lordsmurf's Avatar
    As a person with DV as source, I think you should look into Adobe Premiere Elements, the consumer software for making nice DVDs from DV footage. Easy to use, well-priced at under $100.
    It's an entry-level version of the professional Adobe Premiere CS3, which is what I use.
  16. Member slacker's Avatar
    Jan 2004
    SF, CA, USA
    The latest versions from Adobe are Adobe CS4 Premiere Pro which, I might add, is well worth the upgrade. The scaled down version is called Adobe Premiere Elements 7. Here is the link for the free 30-day full working trial download...
    http://www.adobe.com/products/premiereel/?promoid=121DJGSC_P_US_FP2_PRE_MN&tt=P_US_FP2_PRE_MN
    I have both Adobe CS4 Premiere Pro and Sony Vegas Pro. I found the learning curve less steep with Sony Vegas Pro, and both packages ultimately yield the same quality video. The scaled down version of Vegas Pro is Sony Vegas Movie Studio Platinum Edition version 9.0b. Here is the link for their trial download...
    http://www.sonycreativesoftware.com/download/trials/moviestudiope
    No offense to anyone but I personally found Ulead's (now Corel) VideoStudio and MediaStudio Pro products total crap compared to Premiere and Vegas.
    Good luck!
    Matters of great concern should be taken lightly.
    Matters of small concern should be taken seriously.
  17. Video Restorer lordsmurf's Avatar
    CS4 mostly added some workflow improvements that I don't need at this time. I don't see a whole lot added in terms of features. CS3 was years in the making, while CS4 was maybe a year worth of updates/upgrades.
  18. Member slacker's Avatar
    Jan 2004
    SF, CA, USA
    lordsmurf,
    I agree with your CS3/CS4 compare generally. But for the bug fixes alone...
    I think Adobe has the most posts and largest discussion forum on the planet devoted to issues and problems with their software, with Premiere Pro claiming their fair share. I"ve never seen so many unhappy campers in my life with regard to software. Simply amazing.
    So I figure the CS4 upgrade was completely necessary for them... A ton of fixes.
    (Although still a ton of outstanding fixes or improvements to go.)
    Someone in an Adobe forum recently wrote 'Adobe has created a whole new market with hundreds of companies making workarounds.' Because their software is so goddamn inefficient and buggy.
    But when it works it's awesome.
    Mark
  19. Member PuzZLeR's Avatar
    Oct 2006
    Toronto Canada
    I agree it's a very subjective question that has also been beaten to death. And alot of other attributes play a role in the choice as well.
    But I will say that we need to rehash on such "what's the best editor" threads, like this one, every once in a while. Things change. I've been editing video for years (hobby-wise for the most part) and still benefit from this. If I stuck with VideoStudio forever (which I was using primarily for MPEG-2) I would have never taken advantage of wonderful MPEG functions that newer entries like TMPGEnc MPEG Editor, VideoReDo and Womble provide - just from reading posts about them.
    I will say that VS is all you need for DV if you're a newbie hobbyist. However, it's posts like these that keep one eye open for me as well since I'm still exploring DV.
  20. Member zoobie's Avatar
    Feb 2005
    Florida
    better get used to it...especially after Christmas
    doesn't sony moviestudio come with the superior cinepak codec...
    or is that just pro?
  21. Member slacker's Avatar
    Jan 2004
    SF, CA, USA
  22. Member slacker's Avatar
    Jan 2004
    SF, CA, USA
    I TAKE IT ALL BACK!
    Now that I've used Premiere Pro CS4 for awhile...
    IT SUCKS BIG TIME IN EVERY WAY!
    Go over to http://www.adobeforums.com/webx/.59b6da6f/ to find out just how much.
    Sony Vegas or... NOTHING?
    It may not have all the features of Premiere Pro (most of which are superfluous),
    but it works and works and works...
    Mark
