I need a program which will let me re-label the languages in MKV-files. As in, I've got this MKV-file with 6 tracks, 3 labeled as "English" and 3 as "Russian". I want to be able to re-label several of then, for example into "Unknown" or "Swedish" or whatever.
Is there an app for this? Without having to remux things, that is.
A muxer which will let mux several audio tracks into a single MP4-file and have them both be recognized by iTunes and iPods would help, too, but the important things are the things mentioned above.
You have to re-mux it (not re-encode)
MKVExtractGUI to extract the subs, rename them, MKVMergeGUI to repackage them. Should only take a few minutes
YAMB or MP4Muxer should work for your .mp4 muxing needs
Cheers -
The changing of the names of tracks was for audio, not subs. But MKVExtract and Merge probably work for that too, thanks.
YAMB's muxing of multiple tracks is not recognized by iTunes and iPods (in iTunes, all tracks will play simultaneously at all times, on iPods, only the 1st one will play). I'll try MP4Muxer.
How to delete/switch default language in a MKV file
By gquiring in forum Newbie / General discussionsReplies: 5Last Post: 27th Feb 2015, 20:35 -
Blu Ray to MKV with optioinal multi-language audio/subtitle support
By minerva.thegift in forum User guidesReplies: 10Last Post: 6th Oct 2014, 04:53 -
Remuxed M2TS to MKV gives PGS subtitles without language flag (with Blurip)
By Quasit in forum Video ConversionReplies: 1Last Post: 30th Nov 2010, 13:31 -
Can do BDRebuilder a mkv file with more than one language tracks
By videoten in forum Blu-ray RippingReplies: 4Last Post: 4th Jun 2010, 15:39 -
Trouble adding language track into mkv file
By kruuth in forum Newbie / General discussionsReplies: 1Last Post: 26th Sep 2009, 21:11
