Hi all,
Been a while since I've been here but thought I'd state something, which may or may not be useful. Likely already been said but did a search here and didn't find it, so....
Recently I ran into a .vob issue, I needed to join the files. However, in that rare occasion when renaming the extension to .mpg, the files wouldn't work correctly, no authoring software would fix the issues with the .vob or as mpg, stating it was wrong format or corrupt, etc....
That said, I used I-Media file merger to EASILY join the .vobs. It worked like a charm and then could work with the single video much easier.
I recall getting great help here when I needed it so if I find anything I run into now that may help others, I felt I should try to post it.
Cheers,
Paul
I found it here...
here
included in the pack.
DVD shrink works great for splicing files . I had a loonngg home vid of a 16th birthday party, used DVD shrink to splice it with only what I wanted from it and create the .vobs. Then used the I-Media File Merge to put them together into one. Now I don't have granny talking for 15 min about nothing in the vid.
VOB merger/splitter/editor
By altavistasf in forum EditingReplies: 5Last Post: 17th Oct 2010, 22:16 -
Best merger or joiner without re-encoding software?
By diodox in forum EditingReplies: 2Last Post: 18th Aug 2010, 07:18 -
XM-Sirius Merger
By Epicurus8a in forum Off topicReplies: 13Last Post: 17th Jun 2008, 07:19 -
Audio files now show as "Winamp Media File" in file type
By tmh in forum AudioReplies: 3Last Post: 7th Jan 2008, 14:25 -
MP3 Merger
By Shadowofthedarkgod in forum Newbie / General discussionsReplies: 3Last Post: 10th Jun 2007, 02:53
