Yesterday I had a strange effect on conversion with ULead Mediastudio:
I made a conversion from 50 min DV footage to mpeg-2 PAL SVCD). This took (as usual) 3 hours. I found some errors in the result, edited my DV footage and the converted everything back. As the edited material was shorter then the footage before, I used a higher bitrate for encoding.And to my surprise, the new encoding took about 20 min. only.The result is - in my eyes- perfect.
Why did the new encoding only 20 min? Any ideas?
Mediastudio uses Smart-render....
This means that as long as you keep your original source filed on the same location on your HD it will only render what you edit.
In this case it didn't render for 20 mins but it was checking what part was different, and that takes 20 mins.
greets.P4 2Ghz
512 MB ram
40GB+20GB HD 7200 rpm( dma enabled)
Pioneer DVR A03
Sony 16x DVD-rom
Canon HI8mm Camcorder
Email: sis3970@msn.com -
You're right, even when altering the bitrate only, smart render works in mysterious ways.But you have to keep the temporary files too.
Yes, you have to keep the temp files too, sorry forgot to mention that.
P4 2Ghz
512 MB ram
Pioneer DVR A03
Sony 16x DVD-rom
After MPEG-PS conversion, beginning of the video is extremely fast
By killazys in forum Video ConversionReplies: 7Last Post: 24th Jun 2010, 01:22 -
.MTS to .avi conversion (video seems fast)
By puncho in forum Video ConversionReplies: 9Last Post: 12th Sep 2008, 02:49 -
Quick .avi Conversion to MPEG-2 ?
By christopheramos in forum Video ConversionReplies: 7Last Post: 5th Feb 2008, 19:42 -
No sound conversion MPEG-TS to .avi
By oli60 in forum ffmpegX general discussionReplies: 2Last Post: 22nd Oct 2007, 01:49 -
Video conversion of .rm to .avi or .mpeg with fast forward and rewind
By skv19 in forum Video ConversionReplies: 3Last Post: 23rd Jul 2007, 22:48
