I apologize if this is not in the right forum...
I'm currently using procoder 2 to encode my avi files, then dvdauthorgui for authoring and imgburn for the burning. It's working out great, at least when I play it back on my computer. In my dvd player however sometimes it gets a little buggy like not showing the selectable feature in the menu or not playing an episode from beginning to end (it'll skip to the next episode). Then I looked at the discs I'm using. Sony DVD+R for data and then it has an RW sign right below it??!!! I probably shouldn't be using "for data" discs if I want to play them back on my dvd player right? and how can a disc be DVD +R and RW??? What discs should I use for dvd player use?
thanks
	Those sound more like authoring issues. If you test play the DVD from the files on your HDD do you have the same issues ?
 It could also be a compatibility issue between the discs and your player. Try another brand, such as Verbatim, and see if the problems persist.Read my blog here.
	The RW is just a logo for the DVD+RW Aliance (in charge of both the +R and +RW spec).Originally Posted by uglijimus
 http://www.dvdrw.com/
	If I play the DVD from my HDD I have no problem at all. I also tried the same DVD in my father's DVD player and had no problems with it. Could it be a compatibility issue with the first DVD player I tried it in? You suggested Verbatim. Is this a better brand?Originally Posted by guns1inger
 Also, is there any difference between using a data DVD disc vs. a video DVD disc?
 thanks
  what kind of protection is this?By AaronDude in forum DVD RippingReplies: 0Last Post: 6th Jun 2011, 18:34
  burning and playing blu ray/hd content onto discs onto dual layer discsBy julie_152 in forum Authoring (Blu-ray)Replies: 18Last Post: 21st Sep 2009, 14:36
  Is this a VH glitch of some kind ?By Seeker47 in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2009, 14:09
  what is this for kind of codec.By Cazz in forum Newbie / General discussionsReplies: 1Last Post: 12th May 2009, 16:18
  Is copying gaming discs same as copy DVD/CD discs?By coody in forum ComputerReplies: 24Last Post: 10th Jan 2009, 23:29
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
