Hiya, i have some issues with my encodes.
The problem is, xbox keep re-buffing in some parts of the movies. (so it stop and fills the buffer continuosly)
Data of the source:
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Muxing mode : Container profile=Unknown@4.1 (MKV)
Codec ID : V_MPEG4/ISO/AVC
Duration : 21mn 45s
Bit rate : 3 924 Kbps
Nominal bit rate : 4 109 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16/9
Frame rate : 25.000 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.178
Writing library : x264 core 65 r1016M dbc5ef0
Encoding settings : cabac=1 / ref=5 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=8 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=6,6 / chroma_qp_offset=-2 / threads=3 / nr=0 / decimate=0 / mbaff=0 / bframes=3 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=4109 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=50000 / vbv_bufsize=50000 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
Language : English
Data of the encode:
Video
Format : VC-1
Format profile : AP@L3
Codec ID : WVC1
Codec ID/Hint : Microsoft
Description of the codec : Windows Media Video 9 Advanced Profile
Duration : 21mn 44s
Bit rate mode : Variable (2 pass VBR (average/peak bitrate)
Bit rate : Average = 19.0 Mbps // Peak Bitrate = 51.0 Mbps
Maximum buffer duration : 10000ms
Maximum keyframe interval : 250ms (source framerate x10)
Height : 720 pixels
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.825
I know the bitrate of the source isnt enought to use that WMV settings, but im trying to find a general template for all my HD clips.
Im using Tmpgenc 4.0 express
And the target is to playback it on my xbox360 from a usb drive.
Anyone see anything that should cause that buffer problem?
Thanks.
Results 1 to 1 of 1
Blackmagic Intensity Pro - Xbox 360 to PC capture audio issues
By xmadmardiganx in forum Capturing and VCRReplies: 71Last Post: 22nd May 2011, 17:28 -
Will Xbox play WMV?
By xboxnewb in forum Newbie / General discussionsReplies: 1Last Post: 29th May 2010, 08:35 -
adding subtitles to xbox 360 compatible 5.1 wmv file
By TF2MarkP in forum Newbie / General discussionsReplies: 3Last Post: 30th Aug 2009, 19:16 -
Issues with quality when ripping to network to play via Xbox 360 or PS3
By deadnuttz in forum DVD RippingReplies: 4Last Post: 3rd Jul 2008, 11:37 -
Anyone know how gametrailers.com encodes their HD WMV Videos?
By Mysteriouskk in forum Video ConversionReplies: 5Last Post: 1st Dec 2007, 00:10
