    Aug 2005
    malta
    I have 2 exactly same clips, recorded from different sources (dvdrec & capture card)
    I wish to merge both clips onto a single file, having the left half of the screen playing the 1st source, and the right half playing the second.
    This is usually done when you see comparisons between xbox and playstation and such stuff.
    I actually wish to compare my capture card against my dvd rec for noise settings and such. (and to kill time)
    any particular way/software which does this?
  2. Member gadgetguy's Avatar
    Feb 2002
    West Mitten, USA
    AviSynth
    StackHorizontal()
    Buy My Books
    Aug 2005
    malta
    Originally Posted by gadgetguy
    AviSynth
    StackHorizontal()
    uhm thanks...but how do I run this?
  4. Exactly how you do it depends on the format of the 2 clips. If AVI, then the script goes something like this:
    A=AVISource("C:\Path\To\Video1.avi")
    B=AVISource("C:\Path\To\Video2.avi")
    StackHorizontal(A,B)
    Time to learn some AviSynth.
    http://avisynth.org/mediawiki/StackHorizontal
