I got no reply at all from the Pinnaclesys forum so I'm trying here. Their forum is probably as bad as their Studio software.
1. PINNACLE MOVIEBOARD - When we try to capture a video from an analog videocam to an xp-sp2 pc, using the PINNACLE Studio MovieBoard Ultimate S12 PCI via either Studio 10.6 or 9, the videocam is not recognized. In the source dropdown menu we can see a sort of blank where the name of the analog videocam should appear, but it does not. Clicking on it doesn't help either. BTW, Studio 10.6 was delivered with the MovieBoard kit we purchased!!
Now, if we switch to MovieMaker instead of Studio 10.6, the analog videocam is recognized and the image is captured, but there is no sound at all.
When we go through the same operation with a digital camera rather than the analog one, the capture is perfect, both video and sound, using Studio 10.6 (and MovieMaker for that matter)..
2. PINNACLE MOVIEBOX - If we use the Pinnacle Moviebox instead of the movieboard on the same pc, with a USB connection, all captures are perfect (video + sound) : both with the analog videocam and the digital videocam using either Studio 10.6 or MovieMaker.
Using a different pc gives us exactly the same results as those described above.
Are we using a defective MovieBoard PCI card ?
I only have experience with the MovieBox (which worked fine for me), but it does sound like either you have a defective product, or the product itself just sucks. As one last test you might try downloading a free stand-alone video capture program and seeing what your results are with that; I agree that Pinnacle Studio isn't the most stable pile of code in the world.
Thank you for your comments.
We solved things by downloading a driver from the following site: http://cdn.pinnaclesys.com/SupportFiles/Hardware_Installer/readmeHW10.htm
Pinnacle Studio HD v15 Ultimate
By Sokki83 in forum Newbie / General discussionsReplies: 13Last Post: 3rd May 2011, 22:59 -
Pinnacle studio 12 ultimate - can someone tell me what this guy did please.
By photonianpa in forum EditingReplies: 7Last Post: 12th Mar 2009, 08:40 -
Pinnacle Studio 11 Ultimate ?
By AVCHD in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 22nd Jan 2008, 13:08 -
Pinnacle Studio Movieboard Plus?
By Vantage in forum Capturing and VCRReplies: 1Last Post: 29th Jul 2007, 10:01 -
Pinnacle Studio MovieBoard Plus PCI - Is anyone using this setup
By tug_hill2 in forum Capturing and VCRReplies: 1Last Post: 31st May 2007, 11:51
